VR6 Swap?
Old Nov 6, 2007 | 04:30 PM
  #21
rayveedub's Avatar
Default RE: VR6 Swap?
i can get you the entire conversion right now for about 5-6 g's. also im going gt35r for my 550 hp build. prolly be doing a 2.2l block.
Old Nov 6, 2007 | 04:33 PM
  #22
rayveedub's Avatar
ORIGINAL: WishIWasRWD
My prediction:
550hp Pig = Bacon bits in 5k miles.
thank god your not building it....[8D]
Old Nov 6, 2007 | 04:46 PM
  #23
WishIWasRWD's Avatar
Very true... I don't do well with bacon grease on my tools.
Old Nov 6, 2007 | 04:48 PM
  #24
rayveedub's Avatar
but im sure that everything is perfectly lurbricated at initial start up.[8D]
Old Nov 6, 2007 | 05:20 PM
  #25
Only problem is instead ofdriving around the blockthe first time you test drive it...
You drive to the nearest IHOP
Old Nov 6, 2007 | 06:19 PM
  #26
rayveedub's Avatar
dude are you hungry or something....
Old Nov 6, 2007 | 11:58 PM
  #27
Not anymore...
Mmmm Guinness.
Old Nov 7, 2007 | 10:47 AM
  #28
cincyTT's Avatar
I'm make believe
ORIGINAL: rayveedub
Thinking BF snake manifold, and maybe spring for a hta35r or gt35rst (both will probably cost me $1600 each if i go that route. Might start with a gt35r and send it in to FP and have it built if i feel the need later.) and my own ic setup. I wouldnt do the 2.2 block since you have to use a eurospec crank. Have heard them having problems with cranks and other parts. Going 2.0 with a AEG cast or 2.0T FSI forge crank will be better. If you still want more displacement, a tdi crank and block would net you 2.1L and be all factory parts aswell.
Old Nov 7, 2007 | 12:39 PM
  #29
rayveedub's Avatar
actually i was thinking of doing a ALH crank. but now we are going become a distributor of a rod manufacterers products and i guess i will be staying 1.8 to integrate there product. master plan is to now stay at the lower 9 to 1 cr and just run as much boost as possible and im thinking about some nitrous as well, put it on thumb control or progreesive timing and squirt it from 3000 to 5000 rpm to make up the lag time for drag runs.
Old Nov 7, 2007 | 12:53 PM
  #30
cincyTT's Avatar
I'm make believe
That sounds like a good plan. A stock block and crank will be much safer and not to mention cheaper to build. You should be differnt and if you are or know a good tuner run 10:1 compression instead. With both compression and plenty of displacement, you wont have to worry about lag. A .63 housing on stock displacement hits 20psi at ~4700. The increase in c/r and displacement should be able to knock it down to ~4300rpms.
