washer fluid light??
Old Aug 6, 2007 | 10:44 PM
zero388's Avatar
Default washer fluid light??
After putting on the FMIC I had to take the Aliens off so the bumper would fit right and now the washer fluid light is on all the time. Is there anyway I can turn that off myself or do I need to take it to the dealership?
Old Aug 6, 2007 | 11:13 PM
theTTkid's Avatar
Default RE: washer fluid light??
did you try to look for a solution in your manual?? i guess the other obvious thing would be check the washer fluid level...
Old Aug 6, 2007 | 11:43 PM
eliTTe's Avatar
don't forget to check the blinker fluid too.
Old Aug 6, 2007 | 11:47 PM
zero388's Avatar
No I did not check the manual I dont currently have mine..left it at my dads office... However I doubt there will be any information on how to turn off the warning besides filling the car with washer fluid. I'm sorry I should have prashed the question differently. There is no washer fluid because it all drained out because there is an open hose that the aliens were connected to. Does anyone know how to permanently disable the washer fluid level warning or somehow stop-up the hose so it wont leak? Any suggestions are helpful thanks.
Old Aug 6, 2007 | 11:59 PM
theTTkid's Avatar
haha well... as long as you plug the hose and fill it up with washer fluid the light will go away... im wondering if there is maybe a fuse for it? probably not
Old Aug 7, 2007 | 08:31 AM
diehlryan's Avatar
use a clamp.. been done before.
Old Aug 7, 2007 | 01:12 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: diehlryan
plug with a bolt and use a clamp.. been done before.
Then just fill it up to make it go away
Old Aug 7, 2007 | 06:10 PM
zero388's Avatar
damn this means I have to take off my bumper again.[:@]oh well at least ill get rid of that annoying warning light lol
Old Aug 7, 2007 | 08:45 PM
AudiOso's Avatar
Does this mean that installing a FMIC on a TT will disable the headlamp washers? That's not cool. I don't want to loose functionality of those to gain performance.
Old Aug 7, 2007 | 10:31 PM
theTTkid's Avatar
they do nothing though... if your headlights get that dirty that you really utilze the "aliens" then you dont wash your car enough...
