water meth group buy at vwvortex
Old Oct 27, 2007 | 12:41 PM
randomloginname's Avatar
Default water meth group buy at vwvortex
I am too poor, but maybe some of you arent haha. Just wanted to make sure you guys knew about it, some good discounts.
http://forums.vwvortex.com/zerothread?id=3513264
Old Oct 27, 2007 | 12:45 PM
cincyTT's Avatar
I'm make believe
Default RE: water meth group buy at vwvortex
I would still rather go with snowperformance or devils own over these kits. They are on ebay for about the same prices.
Old Oct 27, 2007 | 12:48 PM
DurTTy's Avatar
besides i like the MAP KIT and the TB spacer withthe snow performance. plus the 7Qt tank from snow can be put in the trunk too.
Old Oct 27, 2007 | 12:54 PM
cincyTT's Avatar
I'm make believe
You really should get a maf kit unless you dont plan on running one. The maf will inject the proper amount faster since it is preactive and not reactive. This means the MAF will see what it needs first where the MAP wont see it until you make the psi, which is a little late.
Old Oct 27, 2007 | 01:07 PM
DurTTy's Avatar
but the maf has a much higher rate of failure. plus the snow performance ones are all going MAP now? or at least thats what i thought.
i see what your saying, i figure MAP will be more consistant since its just a pressure reading, i think the controller sold by snow does min 8 psi and max whatever you like,.
Old Oct 27, 2007 | 01:16 PM
cincyTT's Avatar
I'm make believe
You will always pick what you want, maf or map. The maf issue is always a concern, but they both have their pros and cons. So its really a toss up.
Old Oct 27, 2007 | 01:20 PM
DurTTy's Avatar
either way SNOW is the way to go. [sm=signs007.gif]
Old Mar 13, 2008 | 10:43 PM
MeanAudiA6's Avatar
delete please
MeanAudiA6
Feb 21, 2009 11:23 PM
MeanAudiA6
Apr 3, 2008 06:38 PM
MeanAudiA6
Mar 31, 2008 07:08 PM
MeanAudiA6
Mar 31, 2008 07:07 PM
Audi_Skydiver
Mar 14, 2008 04:06 PM
