water/meth timing
Old Jul 26, 2008 | 05:50 PM
MeanAudiA6's Avatar
Default water/meth timing
i finally tuned a little bit...used unitune and only changed .75 degree advance and noticed i had up to 6 degrees of pull in cylinder 1 and 3 not all the time but some in high rpms..isnt that the max allowed to be pulled before risks?
Old Jul 26, 2008 | 05:52 PM
MeanAudiA6's Avatar
Default RE: water/meth timing
this could be related to me running 100 percent coolant right now...its supposed to be max 70% coolant and 30% water...ive noticed the coolant readings go to 97 degrees cel one notch passed center im gonna empty some and fill with distilled water...forgot to drain after thermostat replacement...lol just refilled with all coolant..its been drained so many times before but this is the first time its been 100% coolant
Old Jul 26, 2008 | 09:28 PM
cincyTT's Avatar
I'm make believe
Thats pretty expensive filling up with all coolant. But yes, 6 is the rule for most.
Old Jul 27, 2008 | 05:17 PM
MeanAudiA6's Avatar
ya at 25bucks per gallon no kidding i sucked some out and replaced with distilled water should more around 60% coolant and 40% water now
Old Jul 27, 2008 | 05:21 PM
MeanAudiA6's Avatar
vag com reads intake temps are 34-36 when driving and when spraying goes down to 22-25 degrees celsius
Old Jul 27, 2008 | 06:20 PM
achTTung's Avatar
nice, thats ambient if not a little less. 22°C ~ 72°F
Old Jul 27, 2008 | 09:22 PM
MeanAudiA6's Avatar
im running the d03 now and gonna try the D04 see if more is better
Old Jul 27, 2008 | 09:32 PM
TTsteve's Avatar
so what are the gains like?
Old Jul 27, 2008 | 11:29 PM
TurboTT920's Avatar
OP, I know you had said your pm wasn't working but maybe you could post here if you have any helpful info related to the w/m questions I had for you. TIA
Old Jul 28, 2008 | 01:04 PM
MeanAudiA6's Avatar
fck this forum cant post!!! ask chance AIM sn is rocket4681 cuz i cant post anyhing over a sentence
