Went on a little shopping Spur.
So i got my tax refund and it was a very nice amount. so i decided i would spend it all on car parts. how fun. Im a at 1200 worth of parts. All labour will be done by myself. I have a 2000 TTQC with APR software and a Forge DV. What i have ordered is below
Peformance: [ul][*]EFU 4u unit for boost, oil, voltage, and spped[*] H&R Rear Sway Bar (21mm)[*]Diesel Geek Short Shifter
[/ul] Mantinence: [ul][*]Interior Air Filter- carbon one[*]ECS Haldex Service Kit With Tool[*]ECS Manual Transmission Service Kit[*]ECS Tuning Ultimate Plus 1.8T Timing Belt Kit[*]ECS Tuning Oil Service Kit With ECS Magnetic Drain Plug[/ul]
I im probally getting the Boost Factory Upgraded Smic next followed by the Blueflame exhuast off ebay. Where else should I look to increase Hp without taking away from reliablity and driveablity?
Do the Modshack Stg III upgrade, all of the parts and it will make a huge difference for you especially with the chip done already. Also, a Boost Guage is a MUST have. Other than that, sounds like you are well on your way
Dont let becca see that you got a the cluster gauges.
Other perfomace parts you can add is getting a dp made and adding water/meth injection. Both will make a rather large increase (~20+hp) over what you currently have. Both will make it faster without taking away from its drivablity.
You HAVE to let me know how it works!
Damn... I'm still waiting for my tax return to order one!
Takes lots to pics!!! PLEASE!!
Did you order the one with the Valentine 1 hook up?
Negative. I live in Canada and I have never been interested in the radar dectetors. I am defintaly going to take some pictures but everything I am going to install already has a write up. I am worried about the Stg 3 Modshack stuff as I don't want the DV to be soo loud. Also I don't think i would like to run front feeds. I might get an upgraded filter, but Im am still sceptical to replace the airbox then add a tottaly differnet Maf and FPR + trying to tune the Boost machine <---NOT FOR ME. I think those parts would do the most damage, if any aftermarket part would be harmful to the 1.8T
