Werid Lighting Problems...
Hey Everyone
OK to start my back up lights do not work at all, I changed the bulbs and fuse and they still are not turning on.... Second my driver blinker sometimes work, or blinker really fast so i changed the bulb and they worked find but now they do not work at all.. and when I press the Brake the signal light turns on.. it doesnt blink just goes on so werid.... and my Pass. headlight always turns on and off. If i turn the lights off and on it will work for a while then turn off.. Can anyone help...
sounds like some wires are shorting out. where? hard to say. Will probably take some searching around.
Had a problem like that back in the day when I was driving a 4000, except on top of the normal light issues, it was a power wire that was chaffed and shorting, and it'd kill my battery. Ended up being a harness pinched in the hinge of my trunk, but I didn't find it until I'd already gone thru 80% of the car, so good luck.
cristiancgarcia
Nov 29, 2008 06:36 PM
