What is this ?
ok so on the dash where it tells you how many miles left you have, now it has changed and is telling me "40:36h " and every minute it moves up. obviously it is keeping time, but of what and how do i change it back to how many miles left i have. Also is there a way to see what my mpg is, i heard there was.
thanks
thanks
ditto, although I did just kind of realize it was impossible to adjust head rest height in the roadster
and to ttkid, my gas gauge is f'd, but I use miles to empty, and I do get a low fuel warning when I think its 2 gallons remain. The problem is just the gauge cluster in my case, sender is fine, and apparently the signal it relays to the low fuel warning still works dandy. Yours likely does too, though maybe you should have a gallon or two of gas on hand while you try to confirm that :-P
