What is this box?
In the backseat area... on the right hand side of the vehicle... mounted behind the side panel adjacent to the first aid kit compartment... there is a small black box about 8" x 4" x 3" in dimensions. I have an aftermarket audio setup and if this is the external amplifier for the stock bose system, I'd like to remove it. Does anyone know what it is?
Side note, does anyone know where to get the small triangularish diamondish shaped metal clips that hold on the interior panels? I had a professional audio installation done a while back and they royally screwed everything up pretty bad. Since then I have redesigned and redone all the audio to a much better standard but am now missing some of these clips from panels. Looking for replacement clips if anyone knows where to get them -shrugs-
If not... Icould easily fabricate them from some sheet metal stock scrap.
BOSE sound system
1-
Radio -R-
q
In upper section of centre console
q
Removing and installing
2-
Front left -R21-/front right -R23- bass loudspeaker
q
In lower front left/right door trim
q
3-
Front left -R20-/front right -R22- treble loudspeaker
q
In upper front left/right door trim
q
4-
Rear right treble loudspeaker -R16- and rear right bass loudspeaker -R17-
q
In rear left and right side trim
q
5-
Aerial amplifier
q
Behind tailgate trim at left
q
6-
CD changer -R41-
q
Behind rear left side trim
q
q
Checking wiring connection
7-
Amplifier -R12-
q
Behind rear right side trim
q
8-
Interior microphone -R74-
q
As of MY 03
q
In dash panel insert
q
9-
Front centre loudspeaker -R70-
q
In front centre of dash panel (in left defroster nozzle)
q
[IMG]local://upfiles/12092/5C2FAA2285F34E78AC6A4F1EAF09C73F.jpg[/IMG]
