what is this? i cracked it...
2 Attachment(s)
Attachment 60307does anybody knows what is the white plastic for? i was trying to clean it and i touched it and it was very brittle and i cracked it.
Attachment 60308 |
RE: what is this? i cracked it...
FOrget whats all in there since i havent seen my car in awhile, but there should be info stamped on there. But again, i havent seen mine in a long time
should i worry about water going in there?
There's a dust filter under there. Although water shouldn't be a major problem, I wouldn't want to smell it after it got wet. https://www.audiforums.com/image/s8.gif
ORIGINAL: beachchair There's a dust filter under there. Although water shouldn't be a major problem, I wouldn't want to smell it after it got wet. [:'(] |
ORIGINAL: diehlryan ORIGINAL: beachchair There's a dust filter under there. Although water shouldn't be a major problem, I wouldn't want to smell it after it got wet. https://www.audiforums.com/image/s8.gif You're referring to a part of the entire plastic closeout cover. If that cover is cracked anywhere, there is a possibility of water getting to the pollen filter. Not Wrong! |
there is a few drains under there, and the filter is raised up, i wouldn't worry about it.
ditto, mine hasa some stress cracks in it from being old ald dried out, mine is opaque as well. I just replaced my filter and saw now signs of it having gotten wet.
On another note, I joined the random esp and abs dash lights club today. I plan on going to autozone to have battery tested and pull codes, will also checkmaf and report back:-P |
mines clear, covers the VIN
is it replaceable?
