what is this? i cracked it...
Old Feb 5, 2008 | 01:30 AM
hotgrass's Avatar
Default what is this? i cracked it...
Size:  54.8 KBdoes anybody knows what is the white plastic for? i was trying to clean it and i touched it and it was very brittle and i cracked it.
Old Feb 5, 2008 | 02:52 AM
cincyTT's Avatar
I'm make believe
Default RE: what is this? i cracked it...
FOrget whats all in there since i havent seen my car in awhile, but there should be info stamped on there. But again, i havent seen mine in a long time
Old Feb 5, 2008 | 03:18 AM
hotgrass's Avatar
should i worry about water going in there?
Old Feb 5, 2008 | 04:02 AM
beachchair's Avatar
There's a dust filter under there. Although water shouldn't be a major problem, I wouldn't want to smell it after it got wet.
Old Feb 5, 2008 | 07:10 AM
diehlryan's Avatar
ORIGINAL: beachchair
There's a dust filter under there. Although water shouldn't be a major problem, I wouldn't want to smell it after it got wet. [:'(]
wrong. that white plastic should be clear. Your VIN# is stamped under there.
Old Feb 5, 2008 | 07:39 AM
beachchair's Avatar
ORIGINAL: diehlryan
Wrong?
You're referring to a part of the entire plastic closeout cover. If that cover is cracked anywhere, there is a possibility of water getting to the pollen filter.
Not Wrong!
Old Feb 5, 2008 | 07:48 AM
sttjackett's Avatar
there is a few drains under there, and the filter is raised up, i wouldn't worry about it.
Old Feb 5, 2008 | 08:10 AM
randomloginname's Avatar
ditto, mine hasa some stress cracks in it from being old ald dried out, mine is opaque as well. I just replaced my filter and saw now signs of it having gotten wet.
On another note, I joined the random esp and abs dash lights club today. I plan on going to autozone to have battery tested and pull codes, will also checkmaf and report back:-P
Old Feb 5, 2008 | 08:23 AM
theTTkid's Avatar
mines clear, covers the VIN
Old Feb 5, 2008 | 11:32 AM
hotgrass's Avatar
is it replaceable?
