What mod can help bottom end on TT?
I would love to see what it would drive like with a stroker crank and bigger pistons... but before I spend that kind of money I'll do the APR Stage III+ to it. I can live with 396hp & 378ft/lbs of torque at peak. [8D]
The weird thing I noticed reading their Dyno results chart for the VVT car is that both hp & torque are lower at low rpm than stock. I guess the bigger turbo takes a little longer to spool up initially.
ORIGINAL: beefyosito
That I definitely plan on in the budget. My exhaust FINALLY FINALLY shipped today and it goes in this Friday. WHOO HOO!! I was wondering ifdoingcamswould have benefits. I don't imagine that the same grinds that work well withthe Garrettwould be as efficient with the K04. I need to talk to Chris at APR and see what kind of difference they'll do on the Stage III+ kit if you buy the FMIC separately. I'm sure there's a price break I'm going to loose if I buy the kit in stages. I figure though at least I can budget for the FMIC and then do my brakes before I build this thing up to the point where it has more go than stop. That's never a good thing.
I still haven't decided between the Brembos or the Wilwoods. I had a Wilwood BBK on a Miata that I had and it was awesome. The Brembo kits are supposedly tuned better to the application. My experience with the Wilwoods was that they weren't finished as nicely as the Brembos but it sure did stop like it hit a wall.
the wilwoods are two peice and the brembos are one peice (unless you get the $2k+ kit) Mywilwoods are cool to the touch in a matter of mins after a hard run where one peices needs x2-3 more time to cool.
