What should i do next...
Old Nov 19, 2007 | 08:59 PM
jojoenglish85's Avatar
Default What should i do next...
Hey guys im new and post my nooby thread earlier. Anyways i just bought a TT 225 and this is what has been done to it so far.
mods:
Rear diffuser from a Audi TT 3.2-cosmetic piece around the exhaust
GIAC performance chip installed by AWE tuning in Pennsylvania-
40 more HP brings her to more than 265hp www.awetuning.com
H&R lowered springs
ITG drop in air filter
XS turbo diverter valve
replaced the timing belt and water pump on 9/11/2007 also did all the brake pads and rotors front and rear,
At the same time I installed new lower ball boints and tie rod ends on the left side-I have all the receipts for this work.
Aftermaket Concepts front mesh Grill. Big improvement over stocker. Car comes with the stock grill as well.
my question is what is neccessary for this car after it has 118k on it?
I was thinking Borla exhaust because i can get one for $400 bucks in the next couple days but what else?
im trying to build it to be a sexy beast lol. Also for the wheels can you direct me to the nearest store online that i can buy some tastefull rims. I want rims with a deep dish on all 4's but don't want to over do it so if you can find me some great measurements for it then it would be great.
Old Nov 19, 2007 | 09:06 PM
cincyTT's Avatar
I'm make believe
Default RE: What should i do next...
A full turbo back would be a nice improvement. As for wheels, try edgeracing, tirerack, 1010tires, and wheelsnext
Old Nov 19, 2007 | 09:13 PM
pitrman's Avatar
check all the hoses for boost leak. time to change all bushings..get the Borla exhaust, get some nice 18"rims ( OZ would be the best) and low profile tires(falken, kumho,yoko..) and you'll get some serious attention ( unfortunatelly most from guys...)
Old Nov 19, 2007 | 11:52 PM
If i go with a deep dish rim set for all tires, which size setup should i go with?
I want 18's all around but as far as the offset, im not sure.
what should i use in the back and in the front? or should i go even all the way around?
Old Nov 20, 2007 | 12:02 AM
cincyTT's Avatar
I'm make believe
18's would be big, but not to big. as for offset and tires go
here and here
Old Nov 20, 2007 | 12:48 AM
WishIWasRWD's Avatar
I have 18's.
They Are Awesome!!![:'(]
I've blown out a tire every other month since I got the car.[:@]
I'm looking to go down to 17's soon.
Old Nov 20, 2007 | 01:07 AM
rear wheels
Front Wheels
would this offset work if not which kind of measurements would i need.
it so confusing buying rims to me, cause i found what i like but i don't know how the measurements work.
Old Nov 20, 2007 | 06:06 PM
cincyTT's Avatar
I'm make believe
You want the ones with the 33mm offset and then throw on some 20mm spacers up front and 25mm spacers in the rear
Old Nov 20, 2007 | 06:30 PM
joshuo's Avatar
ORIGINAL: WishIWasRWD
I have 18's.
wow.
what do you do with your car?
or do you have bad tires or something?
I have had 18's since august and have been fine.
I try to evade potholes, but i've hit a few at night.
Old Nov 21, 2007 | 02:16 AM
ORIGINAL: cincyTT
are the spacers neccesary, also i tried finding them on google and its a lil confusing trying to find the right ones.
