What size gaskets for the 42DD dp
Old Sep 14, 2007 | 12:19 AM
Mobius97's Avatar
Default What size gaskets for the 42DD dp
Looks like I blew out half the gasketbetween the flex section and the turbo. For those that have the 42DD dp (or any other):
Did you change to a better gasket? My downpipe has been on for around a month or so....now it's gotta' come out....crappy ****! Time to order up some Percy's Seal 4 Good metal gaskets!
Old Sep 14, 2007 | 08:12 AM
diehlryan's Avatar
Default RE: What size gaskets for the 42DD dp
I think Nate (cincy) preaches that you dont need these gaskets. could be wrong though.
Old Sep 14, 2007 | 03:23 PM
cincyTT's Avatar
I'm make believe
gaskets.... I DONT NEED NO FU(KING GASKETS!!
Just clean the surfaces and run it without them. They blow and cause more damage than good. I run no turbo to man or man to dp.
Old Sep 14, 2007 | 05:06 PM
Mobius97's Avatar
Ahh thanks, nice to know. I have heard of others doing this as well. But to late I already put the new gasket in. We will see what happens. I got down there and found that the bolts had come loose...this in turn blowing half the gasket out.
Old Sep 14, 2007 | 05:11 PM
cincyTT's Avatar
I'm make believe
Any small exhaust leak will toast them so make sure everything is snug. If you used new bolts, they will come loose again after a short time so you should retighten them after about a week
Old Sep 15, 2007 | 02:50 AM
Mobius97's Avatar
Yep you are correct....I've took herfor a few hard drives today and after each one got under the car and checkedeverything out from top to bottom. Everything is good so far but I will continue to check it periodically.The new gasket and hardware are holding up fine. I just mated up the Borla on Tuesday (FMIC on Sunday ) and now with the exhaust leak fixed it sounds awesome! I am pretty pleased!
AWDrifter
Apr 3, 2009 03:11 PM
theTTkid
Aug 13, 2008 03:17 PM
Wintermute
Feb 23, 2008 11:48 PM
Mobius97
Aug 26, 2007 05:12 PM
