Wheel hop?
Old Feb 23, 2007 | 03:33 PM
moeron7's Avatar
Default Wheel hop?
So i'm looking at these dog bone mount kits, It doesnt really give me a clear definition of what wheel hop is. Can somebody give me a description of what wheel hop is?
Old Feb 23, 2007 | 03:53 PM
XCLR8TT's Avatar
Default RE: Wheel hop?
Definition: An undesirable suspension characteristic in which a wheel (or several) moves up and down so violently that it actually leaves the ground. Wheel hop can be caused by many problems, including excessive unsprung weight, insufficient shock damping, or poor torsional axle control.
Old Feb 23, 2007 | 03:56 PM
moeron7's Avatar
so like if you were about to launch you car and you rev it up and drop the clutch instead of the wheels spinnining, they would actually hop? Is that the same thing?
Old Feb 23, 2007 | 03:57 PM
Dana Reed's Avatar
Drag racing starts;rev the engine real high, dump the clutch, and your wheels will jump up & down (partly) because of engine movement, resulting in a loss of traction. If you want better traction when doing this then you need the kit.
Old Feb 23, 2007 | 04:00 PM
techbod's Avatar
I think its hydropneumatic suspension upgrade rather than a problem used on show cars and expensive
Old Feb 23, 2007 | 04:22 PM
moeron7's Avatar
ORIGINAL: Dana Reed
Ok cool, thats what i was thinking it was. Thanks
Old Feb 23, 2007 | 04:27 PM
techbod's Avatar
yet another drag artistnow why would you ask this question here or was it a copy from AZ?? im beginning to wonder if the forum is part of the said because most questions pertain to mods rather than real problems??????
Old Feb 23, 2007 | 04:38 PM
diehlryan's Avatar
ORIGINAL: avant80@2.6
isn't this a good thing? means no one is having problems.
actually my car is making a hollow howling noise at 3500-4500rpms in all gears. almost sounds like what the vtda soundclip only i have a stock airbox. if i push the clutch and keep the revs at 3500-4500 the sound is not there.
thoughts?
Old Feb 23, 2007 | 04:44 PM
techbod's Avatar
you feed your own question and Im getting board ( seen it done it and got many tee shirts ) that's whats good at my age
Old Feb 23, 2007 | 06:10 PM
moeron7's Avatar
ORIGINAL: diehlryan
thoughts?
When i first installed my vtda, it had that howl, mine was more in between 2800-3000. Does it kind of sound like the noise it makes when you blow on the top of a coke bottle. Kind of a deep whistle?
