Where can i Find...
Old Jan 27, 2008 | 12:58 PM
jojoenglish85's Avatar
Default Where can i Find...
Hey im dieing to find out where i can buy a polished charge pipe for my 2001 ttQ 225...
Where the hell are people getting them?
Old Jan 27, 2008 | 01:17 PM
Murderface's Avatar
Default RE: Where can i Find...
DIY is where you get it
Go to the MkIV FAQ on Vortex and check the polished valve cover/intake part that should give you good instructions how to polish.
Old Jan 27, 2008 | 01:24 PM
MeanAudiA6's Avatar
its not hard to do...just a lot of time. i took the easier way and painted it with high temp semi gloss engine paint. keeps the temps down a little and looks cool as hell. also did the valve cover and soon will be doing the intake manifold. if you go the paint route then go to your local napa and get some etching primer and the 500degree semi gloss engine paint...
Old Jan 27, 2008 | 09:11 PM
cincyTT's Avatar
I'm make believe
sanding, sanding, sanding and more sanding.... did i say sanding?
Start with 80 - 200 - 400 - 600 - 800 - 1000 - 1200 - 1500 and then polish it.
mikees501
May 10, 2012 12:39 PM
b5audi1.8t
Apr 14, 2009 05:47 PM
auditurbo381
Sep 27, 2007 12:50 PM
Propagandalf
May 10, 2006 10:18 PM
