whoops hit a curb last night in the snow
Old Feb 25, 2007 | 07:20 PM
foxrcng11's Avatar
Default whoops hit a curb last night in the snow
so.... slid sideways into a curb going a couple miles an hour (accident) the entire right side hit at the same time and i thought everything was fine at first until i got back on the hwy i noticed my steering wheel is now cocked at a 45 degree angle to the right....
obviously i need an alignment BUT what else did i break in the process and any guess how much its going to cost?
thnx
Old Feb 25, 2007 | 07:21 PM
foxrcng11's Avatar
Default RE: whoops hit a curb last night in the snow
forgot to mention i have the quattro
Old Feb 25, 2007 | 07:49 PM
achTTung's Avatar
Could be bent control arms, bent rims, and/or more, depending on how fast you were going. You'll find out when you go for alignment. My biggest concern, and you'd probably only encounter this if you hit hard enough to make obvious damage, is driving the axle shaft into the trans or differential. Thats extreme though. Do your wheels look off camber by eye?
Old Feb 25, 2007 | 08:46 PM
foxrcng11's Avatar
they look perfect yet... didnt even bend or scratch the wheel... the car drives perfect yet which is the part that i like and it gives me hope lol.... im going to eye it up better tonight but the test will be tomorrow when its on the lift
this sux lol... i just got the money too for my gauge cluster now i gotta put it towards this but thats life lol
Old Feb 25, 2007 | 09:14 PM
achTTung's Avatar
good luck with it, hopefully just an alignment will set you right again.
Old Feb 26, 2007 | 11:13 AM
stephenson27's Avatar
I hit a curb new years eve when avoiding an accident and did quite a lot of damage. My rim was bent, allignement thrown to hell, and I bent my lower control arm which was a decent amout to fix. The most obvious way to tell if there is anything warped, bent, or broken is to use a tape measure and make sure your tire is centered in the wheel well. If the measurment is not the same on both sides then something is wrong.
Good luck!!
Old Feb 26, 2007 | 05:40 PM
foxrcng11's Avatar
well its at the shop right now but.... i had it at the shop that i usually do business with and they said the frame may be bent... if thats the case im screwed i just checked with my insurance and they have my deduc at 1000 which its not supposed to be at and they wont change it this is going to f-ing hurt now... if the frames bent im going to try to trade it in and take a huge loss
Old Feb 26, 2007 | 06:35 PM
XCLR8TT's Avatar
Whoa... you said you hit the curb doing "only a couple miles an hour" I seriously doubt that bent the frame. It takes a serious hit to bend a frame and sliding into a curb there are a whole lot of other things that will break before the frame bends. Was the Carfax on the car clean when you got it?
Old Feb 26, 2007 | 07:37 PM
foxrcng11's Avatar
title was clean when i got it ....just scares me cause the vw dealer (no audi locally here) said they thought the frame was bent but they didnt look at it yet.... i thought it sounded funny as well if i bent the frame im sure my cheap aftermarket wheels wouldve been scratched or bent... the car run perfectly down the road yet and still goes in a straight line when i let go of the wheel so a bent frame to me seems extreme but if it is bent im screwed lol
Old Feb 27, 2007 | 03:08 AM
foxrcng11's Avatar
so its a bent control arm and the wheel is bent i guess so its going to be about 500 parts labor plus the cost of the wheel
kduznetsov
Jan 23, 2012 12:43 AM
tware4021
Feb 25, 2010 04:56 PM
SeaWolfxix
Jan 2, 2008 12:57 PM
drewdq
Mar 11, 2006 01:56 PM
