Will adjusting the actuator do anything?
Old Apr 14, 2007 | 12:51 PM
auditt225's Avatar
Default Will adjusting the actuator do anything?
Old Apr 14, 2007 | 02:22 PM
achTTung's Avatar
Default RE: Will adjusting the actuator do anything?
yeah, it'll change the thing, so the other stuff does more.
Old Apr 14, 2007 | 05:09 PM
auditt225's Avatar
What? I heard that turning the actuator will make it hold boost for a bit longer, th espike that is?
Old Apr 14, 2007 | 06:12 PM
precision tt's Avatar
what it does is hold the wastegate closed a little more. so although it tries to open at the same time, it takes a little longer for the boost to drop down since the exhaust gasses cant bypass as fast with a smaller opening. this wll usually gain you 1-2psi on the top end. but i wouldnt advise it. i did it to see what would happen and it did just that, but i didnt like the way it worked. it felt like it held boost wierd and discharged funny. i think the car overall felt like it worked differently.
Old Apr 14, 2007 | 06:37 PM
cincyTT's Avatar
I'm make believe
Yes, "cranking" the wastegate adds preload to the actuator causing it to need more psi to open it. You will hold boost longer, but will kill the turbo much faster.
Old Apr 14, 2007 | 09:58 PM
achTTung's Avatar
somewhat vague, very minimal question, so i gave a similar answer.
seems we both got each other though, maybe my answer was a bit too out there though
Old Apr 14, 2007 | 10:39 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: achTTung
more than some people deserve.
Old Apr 15, 2007 | 02:53 PM
achTTung's Avatar
well, i didn't mean it in an ******* way, more like smartass.
cantdrive55
Aug 14, 2008 08:32 PM
nrowensby
Jun 4, 2008 08:57 PM
02A418T
Jul 17, 2007 09:01 PM
Lopster99
May 1, 2007 10:00 PM
Authin
Aug 27, 2006 05:11 AM
