Window Motor ?
Old Sep 19, 2007 | 09:38 PM
JewbinTT's Avatar
Default Window Motor ?
D/S window motor took a dump. I have a puchased a used window regulator setup with motor attached. Is there any trick in removing the motor with out letting the gear come out with the wires for the regulator? I have heard this could be a problem.
Any help would be great. I dont want to screw this one up.
Thanks
Jeff
Old Sep 19, 2007 | 09:58 PM
moeron7's Avatar
Default RE: Window Motor ?
I dont know but I think mine is about to crap out as well. Could you do a write up with pics if you do it yourself?
Old Sep 24, 2007 | 06:03 PM
JewbinTT's Avatar
Hey all!
I put the window motor in. It was the easiest fix I have done on any car. very straight forward.
Very easy to not screw up the regulator if you go slow and take your time and know not to just pull the window motor off. ( what a run on sentence) LOL
If anyone needs the bentley print out let me know.
email me at jrubin997@gmail.com
Thanks for the info that helped me save my regulator. oh yeah i have a used D/S regulator in very nice contion they shipped me with motor. Anyone in need?
Jeff
Old Sep 24, 2007 | 09:31 PM
meanse's Avatar
Yes it is a very easy DIY job. You can do it without any directions at all basically. There is a small hole in the bottom of the circular aluminum cover of the hand grip on the door. Put a small pin into the hole until you hear a click, then turn it counter-clockwise and remove it. unscrew the bolt in there, and remove the rubber parts on the corners of the door. Then lift up on the door and remove it. Keep ahold of it, because you have to unhook 3 wire harnesses and the door pully. Then unscrew the 3 screws on the motor, and replace. Goood luck!
joshuo
Jul 31, 2012 12:44 PM
mrocke440
Nov 20, 2010 09:11 PM
blu.suede
Nov 20, 2010 03:15 PM
danieltt
May 8, 2008 03:48 PM
webcrawler
Aug 14, 2006 01:25 PM
