window motor install
Old Feb 26, 2009 | 08:57 AM
Ph3N0m's Avatar
Default window motor install
Anyone have a good write up/how-to on window motor installation. I think mines just took a ****.
Old Feb 26, 2009 | 11:49 AM
Neiman45's Avatar
I have done it twice. Removed door panel. Remove 4 torx screws holding window motor on. Snap on new motor and secure...replace door panel. The most difficult part is getting the door panel back on...
Click here for door panel removal. http://130.74.178.22/aw/body/door-trim.pdf
You can see the motor in the picture.
Old Feb 26, 2009 | 12:03 PM
Neiman45's Avatar
I believe the bolts are T27 or T25. After you remove them from the window motor, getting the motor off is hard because it is on very tight (the gear teeth are very fine and plastic). Just yank really hard or use a wide blade pry device (do not use a flat head screwdriver, you'll damage the motor).
I tested it before I put the door panel back on. Just put your ignition to the on position and use the window controls while it is still detached from the door.
P.S. - make sure you buy the right part beforehand. The driver side and passenger side have different part numbers and are not interchangeable.
Old Feb 26, 2009 | 03:47 PM
Ph3N0m's Avatar
thanks! I saw that I think i'm gonna go ebay and get a used one, mine lasted 9 years (2000) so I figure one that was used for a couple years should last a while. it's supposed to rain tonight though... BOO!!!
Old Feb 26, 2009 | 06:52 PM
Neiman45's Avatar
I bought mine on ebay from a guy in the UK. Paid $65...works great. Good luck, it's not a hard job at all.
joshuo
Jul 31, 2012 12:44 PM
mrocke440
Nov 20, 2010 09:11 PM
CIA
Dec 20, 2008 11:37 PM
Drfeelgood69247
May 22, 2008 06:24 PM
webcrawler
Aug 14, 2006 01:25 PM
