Windows separating? 2002 Audi TT Quattro
Old Sep 21, 2015 | 11:13 AM
psalz's Avatar
Default Windows separating? 2002 Audi TT Quattro
I'm having trouble with both my drivers and passenger side windows where the inside vinyl seal has separated from the window itself. It seems there is some cracking on the inside of it. It's pretty gnarly as the glue smears all over the glass.
Has anyone else encountered this and how did you fix it? Is there a replacement part I can get (easily)?
I'd post photos - but my car is at the body shop already having some things done...and they said they weren't sure what to do with this issue.
Thanks!
Old Sep 25, 2015 | 11:34 AM
majesky's Avatar
Hey I am a big Audi fan, and i also just so happen to do Auto Glass for a living. this issue is difficult. if the glue is coming from the upholstery and getting on the glass the problem will never go away unless the interior is fixed. the glass is easy to replace. your TT has frame-less doors with only two attachments to put it in, just watch and make sure you adjust the height and left to right correctly. IF your windows automatically partially go down when you open the doors try to account for that too.
Hope this helps, Message me if you need more information
OR if you just so happen to live in the northwest I can help you.
nlinesk8s
Jun 21, 2015 03:39 PM
njmurvin
Apr 18, 2014 10:34 AM
algee007
May 10, 2008 02:29 PM
algee007
May 10, 2008 04:22 AM
derrat
May 3, 2008 11:41 AM
