yay for first upgrades!
Old Mar 2, 2007 | 07:31 AM
225tt's Avatar
Default RE: yay for first upgrades!
So if planning to do a water/meth injection, if these cores seem pretty good that would be a pretty good plan?
Old Mar 2, 2007 | 03:56 PM
cincyTT's Avatar
I'm make believe
Any sort of ic upgrade would be benificial. You can also use water/meth to help cool the air also. If you put a nozzle far from the tb near the ic you willlower the ait much further, if you put it near the tb you get much better knock resistance. So you can always run 2 injectors to maximaize the capabilities of water/meth injection. But if you have a nice ic you can just put it closer to the tb to get more of a balance betwen knock and temp reduction.
Old Mar 2, 2007 | 05:15 PM
MeanAudiA6's Avatar
http://www.aquamist.co.uk/cp/sys1/sys1a.html read
Old Mar 2, 2007 | 07:42 PM
cincyTT's Avatar
I'm make believe
I would personally go w/ a snowperformace stage 2 kit. if you go to usrt and talk to scott he is the most knowledgable guy on this subject and can help you greatly. also on the site you can download nozzle sizes to match you needs.
http://usrallyteam.com/
Old Mar 3, 2007 | 03:08 AM
225tt's Avatar
Have already made up my mind, im gona go with the snow performance stage 2 kit. But thanks for the info.
Old Mar 3, 2007 | 04:05 AM
MeanAudiA6's Avatar
good price too. will def think hard about this mod
Old Mar 3, 2007 | 04:31 AM
225tt's Avatar
Yes think hard about it, I already have made up my mind you will see the writeup this summer just gota save the $$$. Waiting for the FMIC and DP, and going to get a Zeitronix system too to help with tuning.Should be set to help me make a few moreponies.
Old Mar 3, 2007 | 02:07 PM
  #18
cincyTT's Avatar
I'm make believe
ORIGINAL: 225tt
IF you get a vagcom you can get just about everything you need except egt's. You can graph timing, boost requested and actual, ait's, and so much more.
Old Mar 3, 2007 | 08:08 PM
  #19
225tt's Avatar
What aboutA/F ratio, vagcom dosent do that? I have a vagcom on the way already, just have to wait to get home to play with it.
Old Mar 3, 2007 | 08:40 PM
  #20
cincyTT's Avatar
I'm make believe
more http://forums.vwvortex.com/zerothread?id=3107410
