AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   *ALL* Greddy III Turbo Timer OWNERS./"BRAKE LIGHT" (https://www.audiforums.com/forum/b5-models-69/%2Aall%2A-greddy-iii-turbo-timer-owners-brake-light-110800/)
Dj Spiel Aug 20, 2008 06:57 PM
Once you install it do you get a "Blinking ABS/BRAKE" on Cluster unit?
1.) Turn ignition...
2.) **3** beeps. BEEP BEEP BEEP
3.) THEY ARE ALL GONE
Only happens when the car is started and it only happened after I installed the TT LAST SUMMER 2007.
I ask now because I am running into Issues with my 99.5 A4. I am getting a "BRAKE LIGHT" on LCD on cluster unit everytime I step on brake "BRAKE LIGHT" on LCD and stays on. I go to rear of the car have someone hit my brake sure enough I have a BULB OUT.
I have tried changing the BULB 3 times nothing! The other side works and so does the one on the top. Can't be the fuse because then none would work...IDEAS?
oiseaux Sep 3, 2015 02:58 PM
Did you ever find a solution to your brake light problem? The same thing is plaguing my 01 A6.
