034 Preformance SMIC
Old Apr 2, 2011 | 03:51 PM
1.8_Turbo's Avatar
Default 034 Preformance SMIC
Anyone running this SMIC? or have any feedback on it? Im just trying to squeeze all the performance out of my APR chip, and though this might help. I have though about FMIC, but I don't wanna deal with cutting up the front bumper. Thanks!
Old Apr 2, 2011 | 04:15 PM
osin34's Avatar
Well unfortunatley i dont have any personal experience with it, but from a modification standpoint, im sure it can only help and especially with only doing the small mods like weve done. anything more than a tune, its not gunna be effective as a FMIC. but from what i know, i would definatley say its good for the guys who arent gunna be doing much more than a tune, and other small bolt ons.
Old Apr 2, 2011 | 04:27 PM
1.8_Turbo's Avatar
Thanks for your input! i think I'm gonna give it a try. BTW, i couldn't help but notice in your Sig that you have an APR tune with a k03s. Does that work well? im thinking about doing the same thing because my stock k03 is pretty much gone
Old Apr 2, 2011 | 04:34 PM
osin34's Avatar
Thats the exact reason i put in the K03s.. my K03 was shot as well, and i actually had bought another used K03 off of a member here, and it was in alright shape, bought it for like 50 bucks, brought it to my mechanic and he looked it over and was like man its better than what you got now but soon youll be back where you are.. turns out he had a mint K03s he had laying around that he was gunna eventually use for his passat if he needed to, so he sold me that one on the cheap and we threw it in.. since my turbo was in the same shape from the day i bought the car, having a newer great running turbo just made me smile.. it was great.. but it works just fine with the APR tune, i boost around 15-17 depending on gear and what not and it holds and drops down steadily to about 10 once you get up top in the RPMs.. if you can find one on the cheap id def suggest it.. i dont honestly think it forwards to better HP or performance but it is a little bigger on the cold side i believe than a K03..
Old Apr 2, 2011 | 04:47 PM
1.8_Turbo's Avatar
ya i guess i was just hoping that the k03s would allow me to hold boost a little better/longer than a ko3. ill probably end up going ko3s for ko4
Old Apr 2, 2011 | 04:51 PM
osin34's Avatar
yea my advice would be if you can get ahold of a k03s in good shape for cheap do it.. if you plan on in the future going k04 with supporting mods then obviously go k04 you just wont see any benefits running a k03 tune.. but the k03s holds and pushes boost well, i just dont have anything to compare it to since my k03 was garbage from the get go.. haha
Old Apr 2, 2011 | 10:28 PM
Andrew149's Avatar
theres a huge post on it on the mk4 gti forums pretty much the smic is fine for the ko3 and k04 and will not do anything much bigger it does still heat soak on a ko3 but not as bad
Old Apr 2, 2011 | 11:10 PM
1.8_Turbo's Avatar
so your saying its most likely not worth the 500 bucks then for the 034 unit?
Old Apr 3, 2011 | 10:28 AM
osin34's Avatar
its got 110% more flow volume.. its gotta help.. im sure it might heat soak a little since its still not out in front of the car but.. i dunno man its up to you!
Old Apr 3, 2011 | 01:29 PM
NHolzschuh's Avatar
for 300ish u can get the godspeed fmic with the pipes off ebay. its cheaper, id assume bigger and well its a front mount. just my 2 cents.
