1.8 and 2.8 trans?
Old Dec 15, 2008 | 09:38 PM
a4r6's Avatar
Default 1.8 and 2.8 trans?
Are the 1.8 and 2.8 quattro trans swappable? Bolt pattern to the block? Obviously they would have different gear ratio's, but would they bolt up? Has anyone ran a 2.8 tranny in there 1.8?
Old Dec 15, 2008 | 09:58 PM
ghost6303's Avatar
a few people do. both 1.8t and 2.8 have 01A bellhousings and are interchangeable. if you put a 2.8 trans on a 1.8t motor you use a clutch for a 1.8t.
Old Dec 15, 2008 | 10:07 PM
a4r6's Avatar
.. auto tranny? putting a car together from the parts car and I wanted to know if they would work...
Old Dec 15, 2008 | 11:34 PM
qUaTtRoA4's Avatar
you can bolt up certain 2.8 trans' to a 1.8T motor...like stated above, you'd use a 1.8 clutch....
the gear raitio's are the same in 1st second and 3rd...but on the 2.8 the revs will be lower in 4th and 5th....
Old Dec 16, 2008 | 10:00 AM
FASTER's Avatar
Tech Slut
I know its already been said, but i run a 2.8 trans in my 1.8t... outer casings on both trannys are identical...
Old Dec 16, 2008 | 01:04 PM
somebody5788's Avatar
So the main differance in the trans is gearing right? The 1.8 is like a little shorter gears to help out w/ the somewhat less torque correct? Im just having a hard time getting a good deal on a 2.8 manual trans...
Old Dec 16, 2008 | 02:24 PM
Mike-2ptzero's Avatar
For the manual the gearing is different for each gear. Even 1st gear is taller in the 2.8 then it is in the 1.8 manual transmission.
1.8t vs 2.8 and at 7k rpm for both
1st = 3.778 - 3.500 ------ 34.2 vs 36.9 mph
2nd = 2.176 - 1.944 ------ 59.3 vs 66.4 mph
3rd = 1.429 - 1.300 ------ 90.3 vs 99.3 mph
4th = 1.029 - 0.943 ------ 125.4 vs 136.8 mph
5th = 0.838 - 0.789 ------ 154.0 vs 163.6 mph
Old Dec 16, 2008 | 03:30 PM
qUaTtRoA4's Avatar
^good to know....thanks!
it looks like 1st and second are pretty similar...but 3rd,4th and 5th have a pretty bug difference...
i think if my tranny goes i would like to go up to a 2.8 trans...hopefully not any time too soon tho...
Old Dec 16, 2008 | 10:11 PM
Yeah they are close, but when you start pushing the rpms up higher the difference really shows. To give you an idea of what I mean.
8k- 1.8t vs 2.8
1st - 39 - 42.1
2nd - 67.8 - 75.9
8500 1.8t vs 2.8
1st = 41.5 - 44.8
2nd = 72 - 80.6
Down side to the taller gears is that it takes longer to run thru that gear and longer to get to the same mph. Just jumping from a 2.8 trans back to a 1.8 trans my trap speeds went from high 120's to mid 130's and my ET went from low 11's to mid 10's.
Old Dec 17, 2008 | 09:23 AM
28audi's Avatar
hey i have a 2.8 so if i wanted to do a 1.8 trans in there i could wats the diff if i did do that and HP diff plz let me know thank you
