2.8 12v to 1.8T swap
Old Jun 25, 2011 | 09:46 AM
vtraudt's Avatar
Default 2.8 12v to 1.8T swap
How much work would it be to swap the (upgrade limited) 2.8 12V to a 1.8T in a 1996 quattro manual trans?
What needs to be changed?
- engine
- engine wiring harness
- ECU
- exhaust
else....
Does the clutch bolt the 1.8T?
Driveshafts?
Can the motor mounts be modified?
Radiator etc?
Old Jun 25, 2011 | 02:42 PM
airguard350's Avatar
Tech Guru
Uh.... Why are you downgrading?
Old Jun 25, 2011 | 02:58 PM
kduznetsov's Avatar
lmfao ^
if it's a 12v its an upgrade, 30v is another story.
Old Jun 25, 2011 | 05:51 PM
vtraudt's Avatar
Originally Posted by kduznetsov
lmfao ^
Both are 'non upgradable' as far as I am concerned. The 1.8T can go for a few bucks (Stage 2 chip) to 'quite fun', and for a few more to 'lots of fun' (350hp). In steps, so not all money is needed at once.
Only 2.8 upgrade: Supercharger. Rare and expansive.
That's why.
Old Jun 25, 2011 | 08:54 PM
Mike-2ptzero's Avatar
- engine
- ECU
- exhaust
else....
Driveshafts?
Radiator etc?
Motor mounts will work, clutch wont seeing the 2.8 and 1.8t do not use the same clutch kit or the same flywheel. If you swap a 1.8t you will not have to change anything in the driveline itself, the 2.8 transmission will bolt right the 1.8t block since the 2.8 and 1.8t both use the same 01A transmission. Many 1.8t owners have swapped to a 2.8 transmission because it has slightly taller gears, have even seen some 2.8 owners swap to a 1.8t 5 speed transmission to make the car quicker thru the gears.
Old Jun 26, 2011 | 08:31 AM
vtraudt's Avatar
So mechanically, no biggi (get 1.8T clutch and flywheel).
How about electrical?
Biggest issue will be to get engine wiring harness I assume?
Old Jun 26, 2011 | 12:25 PM
Yeah. Just have to find a parts car to get everything off of it.
Old Jun 26, 2011 | 12:38 PM
Audisaurus's Avatar
is the wiring harness in just the engine bay or does it somehow make its way into the cabin, i know where to get a few harnessess
Old Jun 26, 2011 | 12:45 PM
Pretty much all in the engine bay, IIRC a few to the cluster inside the car. I actually removed most of my engine bay harness a while after going stand alone. Just got tired off it just tied up in the engine bay and wanted to use the ECU box to hold part of my data recorder.
Old Jun 26, 2011 | 03:35 PM
Audisaurus's Avatar
ive been contemplating this swap also but i have the 30v im sure its straight forward.
