2.8L 1998 A4 Quattro wont start.. anyone got any suggestions ?
Old Oct 14, 2010 | 06:19 PM
ImTheDevil's Avatar
Originally Posted by tellawihuh
I have 1997 2.8 5 speed... had many checked engine when i got the car and ABS light, i fixed the checked engine light and the ABS already , everything was fin for last week and westerday morning, but when i tried the car at noon , it wont start i can hear the gas pump, but no starter or crank... also all the lights is fine on the dash board... when i got the car, i found that the old owner har the neutral safety switch jumped, cause the car starts without stepping on the clutch...do you think it is the ignition switch??? thank you
Shouldn't be the ignition switch since you said you can hear the pump run - are you sure it's the fuel pump though? In my 99, even with an ear to the access cover, the pump was barely audible (this was a new one that works). Maybe you're hearing something else. Could be the fuel pressure regulator - you can check this by pinching/clamping the vacuum line that runs from the FPR. If the car starts then, your FPR is bad.
Old Oct 15, 2010 | 07:59 AM
tellawihuh's Avatar
Smile
what about the Neutral safety switch?? and i am going to try that today...
thank you
Old Jul 4, 2013 | 12:39 PM
TimLoew's Avatar
Default 1996 Audi A4 2.8l v6 wont start.
Hi there I am having the same issue is sounds like I was wondering if you ever solved the problem with your car.
Old Aug 5, 2013 | 09:07 PM
driver2112's Avatar
I just picked up a 98 Audi a4 quattro and replaced thebroken timing belt. Its in operfect time and just cranks and never fires. Any ideas?
Old Aug 5, 2013 | 09:14 PM
ImTheDevil's Avatar
No compression - when the belt broke it smashed the valves. Find an engine or start ordering parts to rebuild that one (valves, timing system kit, full top end gasket kit, possibly pistons and rings, etc)...
Old Aug 5, 2013 | 09:38 PM
driver2112's Avatar
Is it difficult to rebuild both heads. New timing system?
Old Aug 5, 2013 | 09:57 PM
ImTheDevil's Avatar
Get ahold of a Bentley manual (it can be downloaded on this site, although I forget exactly where the link is), and read it through to see. Difficulty depends on your mechanical aptitude. Timing system is timing belt, hydraulic tensioner, tensioner and idler rollers, serpentine belt, water pump, thermostat - they all get changed at the timing service interval.
Old Aug 5, 2013 | 11:10 PM
  #18
driver2112's Avatar
I have all that new already. Why a Bently manual? Its an Audi.
Old Aug 5, 2013 | 11:22 PM
  #19
ImTheDevil's Avatar
Bentley as in the manual, not the car.
Old Aug 5, 2013 | 11:24 PM
  #20
driver2112's Avatar
I know that. Why get a manual for a Bently when its an Audi I have? The heads the same?
