2.8L oil capacity
Old Feb 2, 2012 | 09:20 PM
ParadoxZero's Avatar
Question 2.8L oil capacity
I'm just wondering if anyone has this problem. or if i'm the only one, then what might be wrong with my car. I was looking up specs of my car when i say that the oil capacity is 5.3 quarts, but everytime i change the oil i use almost 7 quarts, and i'm not overfilling it, it takes almost 7 quarts to reach the oil fill line on the oil dip stick. my car is a 1998 A4 2.8L quattro and when i change the oil i use synthetic 10w40, and i use the mobil1 filter, if that helps in any explanation.
Old Feb 2, 2012 | 11:44 PM
airguard350's Avatar
Tech Guru
How freakin' big is your oil filter? When I had a 30v, I used 5-5.3 quarts and ALWAYS hit the fill line with that.
Old Feb 3, 2012 | 03:55 PM
ibid's Avatar
always right around 5.5 qts here for our 98 2.8 (just under 5.5 if you want to get technical) but NEVER EVER 6+ qts so I'm not sure what is going on with your car!
Old Feb 3, 2012 | 07:29 PM
legbuh's Avatar
5 quarts, right between low and high... perfect. Are you sure you have quart containers?
Old Feb 6, 2012 | 02:07 AM
Yeah, what else do they sell? that's why i'm sending this post to find out what's up. if anyone can figure it out, plz let me know.
Old Feb 6, 2012 | 11:03 AM
redmond1501's Avatar
Exactly 5.5 qts on my AHA engine.
Old Feb 6, 2012 | 12:22 PM
FASTER's Avatar
Tech Slut
its possible that the previous owner had an aftermarket oil cooler installed for one reason or another.
Old Feb 6, 2012 | 12:29 PM
murdox's Avatar
Just throwing it out there..
Are you sure you are getting an accurate reading on the dipstick? I recently realized that the orange female piece wasnt clicked in all the way so i was constantly getting a read on the stick that said i didnt have enough oil. Then i messed with it, it clicked in, and was a good inch over the max oil level.
Old Feb 6, 2012 | 02:29 PM
SAudi's Avatar
when i used a mobil 1 filter its uped the oil to maybe 6qts so yeah maybe its normal for the extra oil your putting in, but with a normal fram filter 5.3qts is what im getting
Old Feb 8, 2012 | 08:30 PM
IanWPB's Avatar
Same here. I used a mobil 1 filter and I had to put in 6 quarts also.
