2001 a4 1.8t starting problems
Old Apr 7, 2011 | 11:47 PM
patrixx006's Avatar
thats a video listen really carefully PLEASE ANSWERS SOMEONE!!
Old Apr 7, 2011 | 11:48 PM
patrixx006's Avatar
also it usually takes 2 or 3 times to start it, the car wasnt completely cold so it started the first time...barely..
Old Apr 8, 2011 | 12:22 AM
pbrules10's Avatar
Try checking your suction pump. Look at my thread called "car dieing".
Old Apr 8, 2011 | 02:18 AM
Andrew149's Avatar
Why is the engine light on also? what are the codes for the car on vagcom?
Old Apr 8, 2011 | 07:58 AM
pbrules10's Avatar
When my suction pump was disconnected it took some time to start. It would start and bog for a little then die. I had a check engine for a misfire because the car was stalling.
Old Apr 8, 2011 | 11:05 AM
patrixx006's Avatar
It's bank 2 sensor I have testpipe and revo stage one doesn't clear that
Old Apr 8, 2011 | 01:08 PM
patrixx006's Avatar
thats a video of it on a complete cold start
and i checked the suction pump and its connected
Old Apr 9, 2011 | 01:22 AM
  #18
patrixx006's Avatar
anyone?!?!?!?
Old Apr 9, 2011 | 01:50 AM
  #19
SOONU111's Avatar
I'd try adding some Lucas gas treatment to the next full tank of gas , run a few tanks of gas through the system then change the gas filter again.
Old Apr 9, 2011 | 06:45 AM
  #20
fastcompany's Avatar
try a fuel filter. they have the check valve built in to them to maintain line pressure after you shut the car off. that what it sounds like to me anyways. our fuel rails have a valve on them you can hook a pressure tester up to. check it for fuel pressure start the car check it again and then shut the car off and see if the pressure bleeds down. the suction tube will make the car die after its been running. a fuel pump just doesn't not work when you are trying to start it and then work and work great. ....
