2001 A4 clicks only when in gear, clicks in all gears
Old Sep 17, 2012 | 04:00 PM
AudiBrooklyn's Avatar
Default 2001 A4 clicks only when in gear, clicks in all gears
2001 A4 149,XXX miles 2.8L V6.
It sounds like a card stuck in a bike tire. If its in gear and accelerating it clicks loud from passenger side when downshifting and braking it clicks but as soon as I take it out of gear it stops. It does not do it when idling only driving. Mechanic checked The axle and cv joint and they were fine. Is it the waste gate or a chipped gear tooth? All belts were checked too he said everything looked fine but he couldn't pinpoint it. Thanks in advance
Old Sep 17, 2012 | 04:10 PM
jonbonesjones's Avatar
Moderator
possible heat shield hitting the drive shaft. Does the car shift fine and drive fine?
Old Sep 17, 2012 | 04:22 PM
Yeah it rides fine. Just the clicking noise. Sometimes it's not too loud and sometimes it's real loud it varies. Just got the oil changed last week too after 6,000 miles
Is the heat shield something I should be worried about?
Old Sep 17, 2012 | 07:44 PM
Moderator
sounds like a haetshield. its just annoying but I would find out what the clicking is and fix it before it wears something out or breaks off and cut a hole in your gas line and starts a fire
Old Sep 17, 2012 | 09:48 PM
Ya I gotta bring it to an Audi mechanic the other mechanic couldn't figure it out. How much do heat shields gi for? Are they a pain to put in?
And it's gonna go on fire? Lol I hope your kidding, can't get it checked out for 3 more weeks
Old Sep 17, 2012 | 09:54 PM
Moderator
I'm kidding, really this is something you can do yourself you don't need a , mechanic. It shouldn't cost money either as its still attached to the car.
Old Sep 17, 2012 | 11:15 PM
Awesome I'll find a DIY for it, thanks.
Old Oct 6, 2012 | 11:20 AM
Not the heat shield. Told it could be exhaust manifold leak, front brakes or something with the piston??
Old Oct 9, 2012 | 01:40 AM
Needs front brakes since yesterday. Going to change those and see if it stops the rattling. I had a hole in my exhaust the size of my hand when I hit a bump that I patched up. The exhaust is rusted real bad, thinking the exhaust manifold could be pinched or leaking. Would the exhaust manifold only make noise in gear? Pretty lost about to go to the dealer since my mechanic can't diagnose it.
Also it doesn't click in all gears anymore. It clicks loud when turning right but soft when turning left. Sometimes it will only click when braking or downshifting.
Old Oct 11, 2012 | 10:31 PM
Any suggestions brought it for a second opinion to my friend who works on Audi/VW he thinks its suspension, he can't figure it out though
