2001 Audi A4 1.8t Quattro ECM Question
Can someone please give me a list of compatible ECM's that will work for my 1.8t quattro? I know for other cars it had to be pretty specific (such as same transmission, same drive trane, same engine(duh), etc), but I am looking to replace mine and I dont know what is safe to replace it with. It would be especcialy helpful if you give the part numbers as well. Thank you for your help. I am currently searching, but i am posting this just incase my search is inconclusive.
Thanks
Thanks
Trans code isn't important, but manual/automatic is. The ECU (or ECM, whichever way you'd like to call it) can be recoded in VAG-COM between manual and automatic transmissions with relative ease.
2001-2001.5 would be a 018CH and a 018M ECU. There might also be a few Passat ECU's that work too.
The 018M came in the early 2001 and the 018CH for the 2001.5.
The 2000 ATW came with a 018P ECU for the manual transmission(FWD and Quattor) and a 018Q for the Tip, the 2000 is one of the only years that you can not switch those 2 ECU's into the other car and can not be recoded to work in the other. Even the tunes for the 018P wont work in the 018Q ECU.
daze614
Apr 9, 2013 03:15 PM
