2001 audi a4 non Quattro transmission question
Old Feb 12, 2014 | 12:06 AM
Audia4turbo323's Avatar
Default 2001 audi a4 non Quattro transmission question
I recently purchase a 2001 audi a4 4 cylinder automatic. It had a blown transmission. I bought a used transmission and put it on and it's stuck in one gear only and on the dash it's highlighted on the D only while it's on park . Please help me
Old Feb 12, 2014 | 09:58 AM
mtroxel's Avatar
1. You need a VAG-COM. We'd all be guessing without more data.
2. Are these the same symptoms as the "blown" tranny?
Old Feb 12, 2014 | 05:33 PM
On the old transmission it was stuck in 3rd gear and it had a loud noise. On this one it just stuck in one gear doesn't shift from there .
Old Feb 12, 2014 | 07:21 PM
mtroxel's Avatar
OK, different symptoms.
Just re-read your first post. So when you put the selector lever in P, the dash shows the tranny is in D? If you move the lever to N, does the dash show something like 2?
What I'm wondering is, did you get the cable from the shift lever way out of adjustment when you put in the new tranny? Does it ever go into Park? Maybe the lever cable is so out of adjustment that its not moving the shift linkage the way you think it is.
Old Feb 13, 2014 | 09:37 PM
When it's on any gear the dash lights up on the D only the transmission goes into reverse and drive but it only gets one gear doesn't shift or anything
QUOTE=mtroxel;1463690]OK, different symptoms.
What I'm wondering is, did you get the cable from the shift lever way out of adjustment when you put in the new tranny? Does it ever go into Park? Maybe the lever cable is so out of adjustment that its not moving the shift linkage the way you think it is.[/QUOTE]
Old Feb 13, 2014 | 09:38 PM
Do u think maybe something with the fluid or sensors ?
Old Feb 13, 2014 | 09:40 PM
The car those goes into park and netroul it's turns on fine to
Old Feb 14, 2014 | 02:19 PM
Mark C's Avatar
You bought the same transmission, with the same three letter code on the tranny tag, correct?
Old Feb 14, 2014 | 06:46 PM
mtroxel's Avatar
^^^Good question.^^^ If it is the same code, you really need a VAG-COM to see what gear the tranny thinks you're in and go from there.
Old Feb 15, 2014 | 09:42 PM
Yeah the same 3 letters today I check the oil and it wasent full I put 3 and it still need some
Audia4turbo323
Mar 6, 2014 11:39 PM
HeadkickHarris
May 1, 2013 06:41 PM
a41.8Tblk
Oct 18, 2011 04:57 PM
Papa_Dios
Dec 29, 2010 06:10 PM
mwild616
Mar 1, 2010 11:26 AM
