42 second engine change
Old Mar 22, 2010 | 08:53 PM
Tourbo24's Avatar
Default 42 second engine change
hahah this is crazy ^^ http://www.youtube.com/watch?v=te48ucoEvFI&feature=grec
Old Mar 22, 2010 | 08:58 PM
CCA4's Avatar
LOL thats the most absurd thing i've ever seen!
Old Mar 22, 2010 | 09:22 PM
Mr. Phil's Avatar
how did they get the trans hooked in so effing fast?
Old Mar 22, 2010 | 09:39 PM
vgo's Avatar
vgo
BS! theres an engine in the back and the front is a dud!
Old Mar 22, 2010 | 10:26 PM
joenelson7687's Avatar
Im calling bull on that...theres no way...
+1for engine in the back and front is a dud....
Old Mar 22, 2010 | 10:48 PM
kayakman13's Avatar
I'd agree. That tranny could not hook up so quick. Also, did anyone see fuel lines being unhooked? Coolant? Air? I saw none of these things unhooked or reinstalled.
Old Mar 22, 2010 | 10:49 PM
Mr. Phil's Avatar
yea im pretty sure u have to take out the axle before u do a trans pull??
Old Mar 23, 2010 | 01:48 AM
Msnickbroderick's Avatar
Actual WIZARD
I didnt see ANY electrical connections, fuel hookups, coolant drained or axles pulled. That engine bay was completely stripped... I think if you set a car up a certain way, it might work, but not, for an average team.
Stop it at 1:21 and take a good look at the bay
Old Mar 23, 2010 | 09:13 AM
mikekey's Avatar
I think you're right, if they aren't cheating, then they've set the car up to do that. They probably aren't even using a rad, removed all accessories, etc. They may even be using fuel already in the system, thus the very short distance.
This would be a great one for Myth Busters
Old Mar 23, 2010 | 06:00 PM
CCA4's Avatar
I agree. There didn't appear to be a radiator, and the car was obviously set up to facilitate such a quick change. If i had to guess, i'd say there was no coolant, fuel, no accessories, belts, etc. You can run a motor that small for 30 seconds on like a teaspoon of gasoline, they prolly just primed both motors. as for the tranny, goin that slow you could probably make the hook up with thumbscrews or somethin lol
