96 a4 driver side window fell off track
Old Aug 13, 2011 | 05:29 PM
Mattt6511's Avatar
Default 96 a4 driver side window fell off track
Hello my a4 window fell off the track I know some of you have experience with this. I removed the door panel and I found a green broken clip that seems to attatch to the regulator. Can I just replace the broken clip? Or do I have to remove and replace the entire regulator?
Old Aug 13, 2011 | 06:47 PM
raudi28's Avatar
I had this same problem in my car. I have seen just the clips on ebay, but everyy shop or store i went to told me the whole regulator must be replaced. Most likely to make money. But if you can find the clips im sure it can be done. I replaced my regulator with aftermarket and now when i roll the window up it will roll itself down sometimes.
Old Aug 13, 2011 | 07:11 PM
Tweaked's Avatar
Is this what you are talking about?
Audi B5 A4 Quattro 1.8T > Interior > Window > ES#10186 Audi Power Window Regulator Repair Kit - 8D0898015A
If so, I recommend a complete new regulator. It will save you a lot of headaches and repeat failures. Usually when the guide clip fails, the cable is shot too or the pulleys are close behind.
Old Aug 13, 2011 | 07:29 PM
Mattt6511's Avatar
Hello no the clips are larger blue clips but your probably right I called Audi and they said to replace the entire regulator. The clips I found were on eBay for around 4 bucks a piece.
Old Aug 13, 2011 | 07:48 PM
Tweaked's Avatar
I agree with them. Replace the whole regulator.
PeterCS
Jul 29, 2013 08:36 AM
ed1404
Aug 9, 2011 04:10 PM
Mr. Phil
Aug 29, 2009 12:42 AM
nitro_rider2001
Oct 12, 2008 09:07 PM
JohnnyBravoA4
Jul 25, 2006 02:50 AM
