97 1.8t ATF Recommendations?
Old Jul 11, 2012 | 09:54 PM
PacificA4's Avatar
Default 97 1.8t ATF Recommendations?
My 97 A4 1.8t FWD has gone 128K so far. Takes a long time to shift out of 1st sometimes. Don't know if the trans was ever serviced so I'd like to change the fluid. Whats good? What do you guys use?
Old Jul 12, 2012 | 01:47 PM
z28pete's Avatar
Best things for transmissions is to use what the user manual calls for. Can't go wrong buying the fluid from a VW Audi dealer. The price will be higher but for 100K interval it won't make or break you.
Old Jul 12, 2012 | 02:37 PM
mtroxel's Avatar
It might be fluid. But then you might dump $200+ on fluid and filter, and have to drain it all back out because that wasn't it. I think you need to VAG-COM that, even if you have to pay for it. See what codes are in the TCM.
BTW, I agree with z28pete, you really need to be a choir boy when it comes to ATF fluid. Either Audi, or that Pentosin brand ATF has the same specs.
Old Jul 16, 2012 | 12:40 AM
PacificA4's Avatar
Trans fluid is good for 100K?
Will do, thanks guys
04A4Q
Oct 2, 2009 06:12 AM
rykful
B7 Models
Apr 12, 2009 08:46 PM
DeezS4
Oct 3, 2006 03:09 PM
mattn2005
Sep 20, 2006 12:01 AM
coheed
Jul 20, 2006 06:17 PM
