97 A4 Quattro auto trans front diff seal replacement
Old Jul 4, 2009 | 09:36 AM
cnterline's Avatar
Default 97 A4 Quattro auto trans front diff seal replacement
anyone change this seal ? or have a thread for diy,changed fluid now its leaking from rear seal,it probably already was but now that I topped it off its really leaking more then it was,its the seal in front of where the driveshaft bolts to the transmission
Old Jul 4, 2009 | 01:22 PM
auditech79's Avatar
Thats called the prop shaft seal, and no its not that hard to replace. You just take off the prop shaft from the trans. Buy new bolts because those are a stretch design and have to be replaced. Now pull off the flange that bolts to the trans by removing the large torx in the middle of the flange. Now that thats pulled out gear oil will leak out. Pry out the seal with a pry bar or screw driver CAREFULLY! Then just tap in the new seal until its flush. Put it back together and top off the gear fluid. Not transmission fluid.
Old Jul 4, 2009 | 09:35 PM
Interceptor's Avatar
Ahhh crap. Little worried now... When I thought my rear seal was leaking we just put the bolts back in with some threadlock. My buddy was very afraid of the removing the shaft because there was warnings and the Bently called for useless re-calibration junk for the shaft that would cost $$$.
jlight113
Dec 16, 2012 09:31 PM
obryan44
Nov 22, 2012 08:47 AM
mr peepers
Nov 2, 2011 09:44 PM
corndog
Mar 5, 2007 12:32 AM
