'99.5 A4 1.8TQ on Ebay
Old Oct 23, 2004 | 02:50 PM
audiboy1618's Avatar
Default RE: '99.5 A4 1.8TQ on Ebay
very sad
Old Oct 23, 2004 | 06:29 PM
oscar_3's Avatar
christ that is a nasty bumper
Old Oct 23, 2004 | 07:46 PM
shon's Avatar
ORIGINAL: SlimChriz
Its Kinda like that hot girl you though about goin out with that had that huge space between her front teeth... It could be sweet but itll take some dental work
except the girl that liked me in high school with the gap in her teeth wasnt hot... she needed more than dental work..
Old Oct 23, 2004 | 10:03 PM
Nemick's Avatar
The reconstructed title would make me a bit dubious, but i like the color. Is that an original color option?
Old Oct 23, 2004 | 11:07 PM
SlimChriz's Avatar
Lol well I found out after I left High Shcool that there were to hot chicks that liked me....DOH!
Yah it says it was crashed but was only body damage...Riiiiight thats why it wasnt drivin in four+ years
Old Oct 23, 2004 | 11:49 PM
oscar_3's Avatar
Title Check
1999 Audi A4 1.8T Quattro
VIN
WAUCB28D0XA275279
Body Style
Sedan 4 Door
Country of Manufacture
Germany Review the Vehicle History Records below for details on the following potential problem areas with this vehicle:
Vehicle Description WAUCB28D0XA275279
Title Check Records found
Problem Check No records found
Odometer Check No records found
Vehicle Information No records found
Full History Records Found
Problems Found!
Abandoned No Abandoned Records Found
Damaged No Damaged Records Found
Fire Damage No Fire Damage Records Found
Grey Market No Grey Market Records Found
Hail Damage No Hail Damage Records Found
Insurance Loss No Insurance Loss Records Found
Junk No Junk Records Found
Rebuilt/Rebuildable Rebuilt/Rebuildable Records Found
Salvage Salvage Records Found
Your vehicle checks out!
NHTSA Crash Test Vehicle No NHTSA Crash Test Vehicle Records Found
Fire Damage Incident No Fire Damage Incident Records Found
Frame Damage No Frame Damage Records Found
Major Damage No Major Damage Records Found
Manufaturer Buyback/Lemon No Manufaturer Buyback/Lemon Records Found
Odometer Problem No Odometer Problem Records Found
Salvage Auction No Salvage Auction Records Found
Water Damage No Water Damage Records Found
Vehicle Information
Accident Data No Accident Data Records Found
Corrected Title No Corrected Title Records Found
Driver Education No Driver Education Records Found
Duplicate Title No Duplicate Title Records Found
Emission/Safety Inspection No Emission/Safety Inspection Records Found
Livery Use No Livery Use Records Found
Government Use No Government Use Records Found
Police Use No Police Use Records Found
Rental/Fleet No Rental/Fleet Records Found
Repossessed No Repossessed Records Found
Taxi Use No Taxi Use Records Found
Theft No Theft Records Found
We have searched the Experian Automotive National Vehicle Database of insurance, DMV, and auto auction information and found the following 10 records for this 1999 AUDI A4 1.8T QUATTRO. Note the highlighted rows for potential issues that could affect the value of this vehicle.
Date Location Mileage Description
1999-10-18 OR 830 odometer reading from dmv
1999-10-21 portland, OR title
1999-10-21 portland, OR registration event/renewal
1999-12-14 portland, OR registration event/renewal
2000-02-03 portland, OR title
2000-02-03 portland, OR salvage
2002-06-21 OR 1029 odometer reading from dmv
2002-07-05 mount hood parkdale, OR title
2002-07-05 mount hood parkdale, OR registration event/renewal
2002-07-05 mount hood parkdale, OR reconstructed
Check with the seller to ensure that the recall work was completed on these items.
1996 : Horn may work only intermittently, due to insufficient electrical ground contact.
1996-97 : Discharge of static electricity in low-humidity conditions can activate driver's airbag when driver enters or exits car.
1996-97 : The plastic ignition switch housing can fracture causing the ignition key to stick and making certain electrical accessories (windshield wipers, headlights) inoperative.
1997 : Rear-seatbelt retractors may not lock properly, or may not remain locked.
1997-99 : Control valve in vacuum hose may not open or close fully at temperatures below four degrees (F) under certain conditions; could cause insufficient vacuum to be provided to brake booster.
1998 : If engine backfires during cold-start, an air screen loosely seated in airflow meter can become damaged; screen pieces could enter intake system and prevent the throttle plate from returning to its full idle position.
1998-99 : Some tie-rod seals may not seal properly; if moisture and/or dust enters swivel mechanism, bearing could wear over time.
Trouble Spots
Check for these possible problems when test-driving and inspecting this vehicle.
Brakes : Jump starting a dead battery, or charging the battery with more than 16 volts, may blow the fuse to the ABS system. (1996)
Cruise control : The cruise control may not hold the set speed requiring replacement of the vacuum servo. (1996)
Dashboard lights : The check-engine light may come on with less than three gallons in the fuel tank. This can lead to a lean misfire. (1996)
Dashboard lights : Using cheap gas can cause carbon buildup on the valves, pistons, and combustion chamber, which will cause poor idling and illuminate the check-engine light. (1996)
Engine misfire : If the battery is disconnected, the engine may idle rough or lack power requiring recalibration of the throttle valve control module. (1997)
Fuel gauge : The fuel gauge may not register full, due to a bad electrical ground connection. (1996)
Hard starting : The engine speed (crankshaft position) sensor can come loose causing the engine to crank, but not start. (1997-98)
Repair Costs
Wondering what it will cost to fix this car if something goes wrong? Here are some commonly repaired items on all cars and how much it would cost to fix each item on a 1996-2001 Audi A4. (Note: this information is general and does not represent repairs that the specific vehicle listed may require.)
Commonly Repaired Item Typical
Replacement
Cost
A/C Compressor $1,065
Alternator $615
Automatic Transmission or Transaxle $1,540
Brakes $280
Clutch, Pressure Plate, Bearing $910
Constant Velocity Joints $710
Exhaust System $730
Radiator $640
Shocks and/or Struts $880
Timing Chain or Belt $280
Old Oct 24, 2004 | 01:29 AM
SlimChriz's Avatar
How much damage do you have to get for them to total a year old $30K car wit no miles?
Old Oct 24, 2004 | 04:37 AM
  #18
NATURALins's Avatar
Yea i have a 99.5 1.8t quattro that same color... no pic yet tho... and i would never put something stupid like that on the front
Old Oct 24, 2004 | 04:47 AM
  #19
NATURALins's Avatar
theres a pic of my 99 1.8t quattro with a Neuspeed k04 turbo kit... i really need exhuast im just not sure what to get.
[IMG]local://upfiles/3108/2B0B08F04EB4415F822BF4642C0A4479.gif[/IMG]
Old Oct 25, 2004 | 12:29 AM
  #20
blades's Avatar
Member
Is it really wise to have dissimilar size tires front & rear on a Quattro though? Granted, there is only .1 inch difference in diameter, but I would think with a Quattro you'd really want to keep them identical.
