99 A4 FWD rear camber high
Old Feb 19, 2010 | 10:00 AM
IIF3LIXII's Avatar
From: Originally from Connecticut Now in New Hampshire/Manie
well yahh.. any drive wheel should be completely adjustable. excluding strait axles and floaters...
Old Feb 19, 2010 | 06:28 PM
audirpm's Avatar
I read you're thread about the custom exhaust. I've got a Dynomax super turbo muffler at the shop, i know its not the best muffler at only $35. My question to you is what are your thoughts on what the sound me be like? We've got that muffler on a 944 race car right now, straight piped from headers, and its WAYYYY too loud. Just wonder what you think it would sound like with a stock cat and res.
Old Feb 22, 2010 | 08:24 PM
beat180's Avatar
Originally Posted by audirpm
Thanks for the update, i mostly do alignments on quattro's i suppose. I also second what your saying, just checked my shops Alldata. I know the quattro's rear setup is a fully adjustable rear camber and toe through the accentrics. It would appear as though you could elongate the bolt hole for the hub/lower strut to axle beam though to give you the correct camber. I know on 944's we have to do this all the time because the rear banannas are aluminum and are always bent costing a billion dollars to replace so we just elongate the existing holes in the torsion tube to allow for correct camber.
hmm that's a good idea. if it fails then i'll be looking at picking up a new axle beam anyway.
Old Feb 23, 2010 | 08:48 AM
IIF3LIXII's Avatar
first, is it s 1.8 or a 2.8l? on my 2.8 12v it had a nice sound with the res still on there. was like a muffled hi-tech type of sound. after i had removed the res and bent up something custom its now more aggressive with a deeper tone. it is louder but not to loud unless you drive it loud... also brings up the revs faster with the exhaust opened up. i suggest removing the res with your custom pipes as long as you dont mind the tone that you get in the car with out it...
Old Nov 21, 2017 | 10:29 AM
Pilot2's Avatar
Default Any updates?
Anybody sort out a solution for changing camber on the 1-piece FWD rear axles? I am looking at shim kits but they only adjust 1 degree of camber, probably not enough.
DrBeaker
Nov 17, 2010 11:35 AM
steckrca
Apr 21, 2009 09:46 AM
BrittAudi96
Dec 3, 2008 12:56 PM
czwalga
May 21, 2008 04:51 PM
jason955
Feb 24, 2008 01:27 PM
