A4 1.8 turbo spark problem
Old Sep 28, 2008 | 06:36 PM
adamp91gvm's Avatar
Default A4 1.8 turbo spark problem
i have a 1.8 turbo but it is only running on 3 pistons i have bought a new coil pack and spark plugs and the coil pack works on the other 3 inlets but on piston two back from the front it does not spark im stuck !!!! help please thanks
Old Sep 28, 2008 | 06:48 PM
Jc61990's Avatar
check the gap on the plug
Old Sep 28, 2008 | 07:02 PM
adamp91gvm's Avatar
i have bosh super 4s and its not sparkin from the coil its slelf but is if i change it to another piston
Old Sep 28, 2008 | 07:04 PM
Jc61990's Avatar
bad wire?
Old Sep 28, 2008 | 07:09 PM
adamp91gvm's Avatar
well im hoping so im goin to have a look proper tommorw was just seeing if any one else has had the same problem
Old Sep 29, 2008 | 07:16 PM
adamp91gvm's Avatar
had a look today there is no power from the lead to the coil pack can these be bought separatly ?
Old Sep 29, 2008 | 07:22 PM
onepoint8tee's Avatar
If you have 97-99, replace your ICM on top of the airbox. It controls firing/firing order. It's notorious for failure and causing cyl 2 misfires, etc. Don't drive the car like this though. A misfire is one thing, but driving around on 3 cyl's while cyl 2 gets flooded with fuel is bad bad bad for your cat.
Old Sep 29, 2008 | 07:27 PM
adamp91gvm's Avatar
it is piston 2 from the front looking back towards the bulk head that is not firing ill have a look at this tommorw where abouts is the ICM
Old Sep 29, 2008 | 07:30 PM
Jc61990's Avatar
On top of the airbox, says bosh on it
Old Sep 29, 2008 | 07:31 PM
On top of the airbox. If the coil pack on cyl 2 works on a different cylinder, it's definintely the ICM, just get a new one. They arent too cheap though. Autozone/advance offer one that is Hucco brand which has been proven reliable for around $100.
READ
Buy
