A4 1.8t Sport vs. S4
Old May 14, 2012 | 12:19 PM
CCA4's Avatar
Originally Posted by jonbonesjones
seriously? the 2001 uses the larger spacing spindle? i didn't know this
Based on what I've read, yes. Unfortunately I didn't find this out until after I did the A8/TT upgrade, so I don't know for sure.
Old May 14, 2012 | 01:54 PM
jonbonesjones's Avatar
Moderator
well the tt caliper uses the same spacing as a4 with the smaller mounts or it wouldn't work on all b5s. so i don't think the bigger size is possible. i know the b6 uses the larger spacing. i have a comparison picture somewhere ill throw up.
Old May 14, 2012 | 03:39 PM
vgo's Avatar
vgo
i have s4 brakes front and rear upgraded to 300mm bitch stops 100-0 in a few feet. also have ebc reds and no abs because abs is for pussies
I have no ABS too...im too lazy and cheap to get the ABS fixed lol.
btw, jon does your cruise control work with your ABS down?
Old May 14, 2012 | 03:44 PM
Moderator
my cruise works fine. ihad my and module repaired and it broke again so i just took it out and killed the lights. I'm gonna redo all the brake lines in the summer to completely remove the module and pump
Old May 14, 2012 | 03:55 PM
diannedrc's Avatar
just bought a 2000 a4 with36000 miles. the center dashboard lights are unreadable. can someone tell me what they are about. one is flashing
Old May 15, 2012 | 03:16 AM
sb301's Avatar
Eelpie, you should get the sport suspention!
BTW
Did I mention I have all four shocks and springs for sale? Lol
Old May 15, 2012 | 04:52 AM
eelpie's Avatar
My car is an '01 1.8t with the factory Sport Package, which is essentially the same suspension as the S4.
The A8 brake up-grade will give it larger front rotors than those fitted stock to the S4 . . .
Old May 15, 2012 | 06:44 AM
  #18
bradtyler02's Avatar
Don't forget, you have to have 16" wheels or bigger to upgrade the brakes...
Old May 15, 2012 | 06:50 AM
  #19
eelpie's Avatar
Default My car is an '01 1.8t with the factory Sport Package, which . . .
. . . includes 17" wheels.
Old May 15, 2012 | 07:14 AM
  #20
Moderator
Not true
a8 -312
s4 -321
front s4 also two pots and way bigger.
