A4 2.8 12v remote turbo build
Well I plan on buying up some parts for a remote turbo build and I really have no idea what is going to be needed in order to do the setup. I have a few friends that build turbo cars all day long and was just wondering if I can get some input for the buil like parts, fabrication, time, cost. etc anything that will be helpful.
https://www.audiforums.com/forum/sho...=112670&page=4
Link to 2.8 power thread
i saw the list on GreekA4s parts but Idk if there are any more needed
standalone
injectors
fuel pump
headers
downpipe + exhaust
turbo
wastegate
intercooler
blowoff
intake
internals
clutch + flywheel
suspension
brakes
engine management
turbo
up & down pipes
charge piping + silicone couplers
intake piping
filter
worn gear clamps (t-bolts if you feel)
various hardware (nuts, bolts, etc)
To run 8-12 psi
external wastegate + plumbing
intercooler
injectors
fuel pump
clutch
larger radiator
trans cooler for auto cars.
maybe an engine oil cooler
GreeKA4
***TURBONETICS T3/T04E Turbo-Compressor Trim: 60-1, Turbine A/R:.48 with a 5-bolt outlet MSRP:$936
Turbosmart 38mm External Wastegate, 7psi spring
Greddy type RS style BOV (can be recirculated)
K&N 3" filter
Oil pump
Charge piping + welded BOV flange - 3 inch from throttle body, 2 inch from turbo
Exhaust piping + welded T3 flange
Oil feed line, return line and fittings
Silicone couplers, reducers, and clamps
Hangars for charge piping are included.
K&N 3" filter
Oil pump
injectors
fuel pump
headers
downpipe + exhaust
turbo
wastegate
intercooler
blowoff
intake
internals
clutch + flywheel
suspension
brakes
engine management
turbo
up & down pipes
intake piping
filter
To run 8-12 psi
intercooler
injectors
fuel pump
clutch
larger radiator
do u know how to tune a car for that because theirs no tunes for that so you'll have to pay a lot for a custom tune or buy a management system to tune your car. you'll also have to get an intercooler, and most likely bigger injectors, fpr, ect... for the tune.
why not bag the idea and sell your car and get a 1.8T? theirs plenty of turbo upgrades and tuning options with no real risk of blowing up your car
this has been tried a few times before. it ends up costing more then you paid for the car in the end, and is much cheaper to just sell it and buy a 1.8t. if you are dead set on keeping your 2.8 for whatever reason, you will be figuring most of it out on your own as there isnt much info online about doing this. try the search function.
Im really actually depating selling the car. But I really like the idea of a remote turbo seems that no one really wants to deal with the 2.8's idk why theyre pretty much a 2.7 with thinner walls. If a 2.7t can take the beating why couldnt this car. And if the parts tools and skills are available I cant see why not. Ive also been reading up on a lota diff remote builds
Was checking out this build as well seems pretty awesome of a build but very complicated and time consuming at the same time. deff not a 1 day job
http://forums.vwvortex.com/zerothrea...158428&page=18
bottom7.jpg?t=1223311966
yeah its gonna be a pretty complicated build but im sure in the end that all of the work will pay off as long as the engine and tuning is up to par. sucks that pretty much no one has put there information out there for this build and ill just be going on by what passat builders and vw peeps be doing since the engine is pretty similar. Hoping to get 300 but i doubt it. Ill be fine with just a clean turbo and that extra HP.
If anyone has anymore info on this build please feel free to let me know on what is needed.
Also how hard is it to setup megasquirt in these cars
