A4 b5 facelift arm rest
Old Apr 22, 2011 | 09:05 AM
JASEA4's Avatar
Default A4 b5 facelift arm rest
in the process of buying an armrest ( genuine audi) has anyone fitted one of these to the car and got any tips or pics on how to do it ???
Old Apr 22, 2011 | 09:21 AM
CCA4's Avatar
you referring to the center arm rest that always rips or something different? I've popped mine out a couple times with the intention of re-covering it, but never did get around to actually doing it. If you gently squeeze the two arms together that hold the lid to the lower portion, you can wiggle it to one side and it pops right out.
Old Apr 22, 2011 | 09:39 AM
vtraudt's Avatar
The lid on my 1996 is broken (the rear plastic tabs), so I am looking for a used lid (dark grey cloth).
2 weeks ago, I took the entire center console and center dash out.
I can send you the Bentley printouts (for my model; shouldn't be different for yours).
Off memory:
Starts with rear ashtray removal. 3 bolts (13mm).
Then get the hand brake boot out (took a bit of stretching)
Take the rubber liners out of the center console trays.
Take the 'phone cover' out.
Underneath is another bolt. 13mm also?
Front of the center console has 2 screws connector to shifter plastic piece (side of tunnel). Remove the plastic caps, remove the 2 bolts (not sure if philips head or 10mm or 8mm).
I think there was a wire to discounnect (ashtray?)
Then the hole assembly comes out.
Old Apr 22, 2011 | 09:42 AM
CCA4's Avatar
^^Ahhhh this makes sense. I thought he was referring to just the lid. I fail lol
Old Apr 22, 2011 | 09:56 AM
JASEA4's Avatar
mate that post is spot on thanks
yeah mine doesnt currently have an arm rest in the centre console and just in the process of securing a deal on one , so will be a first time fitment , i understand that under the console there may be a template to cut out to fit a first time arm rest ???
but that post up will help me loads
cheers
Old Apr 22, 2011 | 10:30 AM
vtraudt's Avatar
Now its your turn to find me a cheap lid for my armrest!
cheers
Old Apr 22, 2011 | 10:39 AM
JASEA4's Avatar
what colour lid you looking for
Old Apr 22, 2011 | 11:01 AM
vtraudt's Avatar
Default Armrest lid
Mine is 'dark grey', cloth.
Interior is black, so black (cloth or leather, not sure what variations are out there) would also work.
Old Apr 22, 2011 | 11:18 AM
CCA4's Avatar
If you have $200 you don't feel like hanging onto..
http://www.ecstuning.com/Audi-B5_A4-...Rest/ES431393/
Old Apr 22, 2011 | 11:21 AM
ObnoxiousDrunk's Avatar
Hahahaha!!!!!
