A4 quattro 1999 2.8 crank no start issue
Old Jan 28, 2018 | 11:30 PM
Anton Zhloba's Avatar
Question A4 quattro 1999 2.8 crank no start issue
Hey Guys! I am new here on the forum. Having an issue with my Audi A4 1999 2.8 Quattro that simply didn't start in the morning about a week ago. The engine cranks but doesn't want to run. I have check fuel system - there is sufficient gas pressure and the pump seems to work normally. Ignition system also works well - I can get a decent spark. There is one check engine code which is P0411 "Secondary Air Injection System Incorrect Flow Detected". Any ideas why it might not start? Many thanks in advance!
Old Jan 29, 2018 | 03:39 PM
elduderino200's Avatar
The code you have might suggest one of either of your 02 sensors. They are finicky.
2nd suggestion would be the coolant temp sensor, which is a common failure and causes crank-no-starts.
Lastly, it could be a Crankshaft Position Sensor (aka engine speed sensor), which causes your issues.
Honestly I would try the coolant temp sensor first.
Old Feb 9, 2018 | 01:39 PM
Thank you very much! The issue was with spark plugs! P0411 appeared to be a separate issue that I am dealing with right now.
Heineman21
Sep 1, 2021 10:39 PM
2000audi1.8
Jun 22, 2017 06:28 PM
usmc327
Mar 31, 2012 09:29 PM
