A4 Quattro Driveshaft problems
Old Feb 8, 2009 | 08:27 AM
cnterline's Avatar
Default A4 Quattro Driveshaft problems
its the driveshaft with carbon fiber and steel,no matter where I put the center hanger bearing adjustment it still gets a vibration when I start out making a left or right turn car chatters, also at 40 mph and around 80 mph,shaft was rebuilt but the guy that did it did not do center hanger bearing so I dont know if thats the problem,this also happens with no wheels on the car when I have it on the lift so its def a driveshaft problem ,I had both front axels rebuilt and all 4 wheel bearings are new ,any thoughts thanks Kevin
Old Feb 8, 2009 | 01:39 PM
ghost6303's Avatar
1- you gave no information about the car, year, engine, im guessing quattro?
2- our drive shafts arent made out of carbon fiber from the factory, so you didnt say where you got the aftermarket shaft.
3- our drive shafts need to be balanced before they are put on the car, i bet your mechanic wasnt aware of that.
Old Feb 15, 2009 | 08:42 PM
cnterline's Avatar
its a 97 a4 2.8 12 v quattro,autumatic,the only year the front half had carbon fiber shaft,rear is steel
Old Sep 26, 2010 | 12:01 AM
dan_j_b's Avatar
I noticed my 96 A4 has the same carbon fiber front driveshaft
atomm
Feb 15, 2013 12:31 PM
harryb5a4
Feb 1, 2013 04:20 PM
Rdcarter
Oct 15, 2009 10:38 PM
Splbasshead
May 29, 2009 01:22 AM
JoRP
Feb 29, 2004 05:41 AM
