A8 wheels fit?
Old Jul 14, 2011 | 10:51 AM
HulkB5's Avatar
Default A8 wheels fit?
Im looking to purchase a set of oem a8 size 19".
I wanted to know if they would bolt right up, or if they would even fit.
i need some help from some of you wheel guys!
Old Jul 14, 2011 | 11:39 AM
CCA4's Avatar
Bolt pattern should be the same, the issue (if any) would be width, offset, and ride height. My guess is offset is somewhere in the 40's, width would be at least 8.5." What suspension are you running?
Old Jul 14, 2011 | 01:05 PM
kriptonik's Avatar
Are we talking OEM ones? There are OEM and some replica ones. Replica ones having different ET than OEM ones.
If they are OEM, I believe they are 19X8 with ET 45. I could be wrong on the ET but it's somewhere around there. You may need spacers up front to clear the inner. Other than that, you should be good to go.
Old Jul 14, 2011 | 01:19 PM
jdahlen24's Avatar
Could someone please explain what "offset" is? I've read a few threads on wheels around here, but I still don't understand what offset is.
Old Jul 14, 2011 | 02:51 PM
CCA4's Avatar
Offset is the measurement of how far the mounting surface is off set from the center line of the wheel. Hence the name
This should help:
Its important because when fitting wheels that weren't designed for your car, width and offset can cause clearance issues with suspension components.
Old Jul 14, 2011 | 05:14 PM
jdahlen24's Avatar
Thanks, CCA4. I still didn't quite get it, so I googled and this pic was easy enough for my small brain to understand.
Old Jul 14, 2011 | 05:17 PM
kriptonik's Avatar
That should help.
Old Jul 14, 2011 | 09:50 PM
HulkB5's Avatar
im running stock struts and springs, with sport suspension.
And the wheels are oem.
Old Jul 15, 2011 | 10:50 AM
HulkB5's Avatar
Should i buy the 19" a8 wheels or should i go for maybe brabus v's?
They are 18x8.5 with offset ET35
Like these
Old Jul 15, 2011 | 12:00 PM
CCA4's Avatar
Depends on the look you're going for I suppose. The Brabus wheels you posted are more sporty looking IMO, especially being 18" as opposed to 19". I'm not a huge fan of either style, though I have seen those A8 wheels on a B6 and they looked sick as hell
