ABS
Old Jul 2, 2008 | 10:29 AM
malubeast21's Avatar
Default ABS
Hello,
My ABS and brake light came on simutanelously. I went to a dealership and they said I have to replace my ABS, which will come out close to a $1,000. Does anyone know where I could send in my ABS module to get fixed instead of getting it replaced, which is a lot more expensive?
PLEASE LET ME KNOW!
Old Jul 2, 2008 | 10:34 AM
techbod's Avatar
Default RE: ABS
ABS light comes on dosnt mean the ECU is dead chances are its a wheel sensor what was the code
Old Jul 2, 2008 | 11:22 AM
akielb's Avatar
Default RE: ABS
To get it rebuilt go here - I'm going to be sending mine there is a couple weeks
http://www.modulemaster.com/en/Audi/A4_info.php
Old Jul 2, 2008 | 12:18 PM
euro_2nr's Avatar
Default RE: ABS
^^^ 1+
Send it to module master. Its just your ABS module that costs $240 total. **** all over the dealer, they're a bunch of ******. You can do this yourself in about 30 mins. I sent mine in for my A6.
Old Jul 2, 2008 | 10:06 PM
lawnferie's Avatar
Default RE: ABS
^^^^ +2
best option... sure a lot of people will tell you this
Old Jul 3, 2008 | 02:32 AM
steezybme's Avatar
Default RE: ABS
^+3 im sending mine there... and to be in your best interest dont ever send your car to the dealership... Seriously ever... you will get raped every time. Best thing to do is to learn your car yourself! if not look up a local shop (preferably bosch certified) but any will save you tons of money... If you have any problems and you work on it yourself, get on here 1st. search then if still ?????'s then post...
Old Jul 3, 2008 | 10:06 AM
CRAZYHAWK's Avatar
Default RE: ABS
I'm with Dave on this. Try cleaning the wheel sensors and reset
the codes.
https://www.audiforums.com/m_99381/tm.htm
Old Jul 3, 2008 | 07:24 PM
thepirate's Avatar
Default RE: ABS
i had the same problem a few weeks ago. turns out i had a bad cv boot that was spraying grease all over the inside of the wheel and brake calipers. i got under there and cleaned off the sensors and i havent had a problem since....
