abs brake pedal noice hearing
Agreed ^^. Or it could just be a sensor not positioned close enough to the ring.
With VAG-COM you can read the fault code in the ABS module, to find out which wheel sensor is causing the problem. Often this issue can come up after suspension/brake work has been done.
NorthernComfort
Sep 19, 2007 07:54 AM
