abs brake pedal noice hearing
Old May 20, 2013 | 01:35 PM
korpscom712's Avatar
Smile abs brake pedal noice hearing
When i brake slowly till o the brakepedal goes a bit up an down and make a metal noice somtimes the abs bulb turns on and left red light flashing
What wil that be
Old May 20, 2013 | 01:37 PM
Nebuchadnezzar's Avatar
This sounds like a bad ABS sensor on one of your hubs.
Old May 20, 2013 | 02:16 PM
MetalMan's Avatar
Agreed ^^. Or it could just be a sensor not positioned close enough to the ring.
With VAG-COM you can read the fault code in the ABS module, to find out which wheel sensor is causing the problem. Often this issue can come up after suspension/brake work has been done.
maskell_91
Feb 2, 2015 10:38 AM
Mhuntington
Apr 24, 2013 10:48 PM
mrk3cobra
Jun 23, 2009 11:17 AM
NorthernComfort
Sep 19, 2007 07:54 AM
smshep85
Jan 11, 2006 04:22 PM
