ABS land brake warning lights are on
Old Feb 24, 2009 | 02:15 AM
Quattro_1.8t's Avatar
Default ABS land brake warning lights are on
My ABS light is on, brake light is flashing on the dash as I drive. My brakes work prefect, so I dont know what the problem is. ABS works fine, car stops normal. Any ideas?
Old Feb 24, 2009 | 02:49 AM
pyropenguin's Avatar
ABS control module is going bad, needs to be rebuilt. or one of your speed sensors got screwed. probably the control module.
www.modulemasters.com <-- they can rebuild it for $250.
Your car is fine to drive, just be aware your car wont have ABS or EDL (our electronic lockers) until you get it fixed.
Old Feb 24, 2009 | 04:43 AM
Nvm I reset the ecu, lights turned off and havent came on since.
Old Feb 24, 2009 | 05:18 AM
One of the traits of the bad abs module is that it's intermittent. Now you'll know what it is if it comes back!
Old Feb 24, 2009 | 11:35 AM
brrman's Avatar
yep - another test it to try and scan the ABS module with the VAG. If it can't connect then it is definitely a dead module . Rebuild for $250 or a new electronic replacement for $450.
Be aware that without ABS your rear brakes will tend to lock early and throw the rear end out, especially on ice.
Old Feb 24, 2009 | 09:17 PM
The Bishop's Avatar
Hooked on modulemaster works for me!!!
Old Feb 24, 2009 | 10:25 PM
That's what I've always read but when I auto-x'd my fronts locked up before my rears.
Old Feb 25, 2009 | 12:42 PM
brrman's Avatar
I just had to replace my ABS module. My rear end would lock up really easy while my ABS was out. Might have something to do with road conditions.
Old Mar 6, 2009 | 10:50 AM
Mattazaudi's Avatar
I am having the same issue but only when I turn my headlights on. If I turn the ignition on lights on then crank the car nothing happens. but if the car is running and I turn my lights on the ESP, ABS light comes on, and brake light flashes. I just installed some new aftermarket HID's, Im thinking its too much current draw when they start up. anyone know if the lights and ABS are on the same circuit???
edit: by they way I dirive a 2002 A4. 1.8T
Old Mar 6, 2009 | 11:08 AM
Audacity's Avatar
my module has been bad since the day that i bought the car, i have never had a problem with hanldeing it.
