Abs light on
Old Aug 17, 2012 | 02:50 PM
Dublin's Avatar
Default Abs light on
A couple weeks ago i diagnosed my abs module as no good.So yesterday i replaced the module and i was able to connect to the module now and the abs light and flashing e-brake light turned off BUT the abs light in the center led remained on. So then i figured the new abs module is reading a code so i went and got the codes checked. I didnt get any codes in any system so i cant figure out why this light would be on.
Old Aug 17, 2012 | 04:28 PM
MetalMan's Avatar
What did you use to scan the car? VAG-COM? If you used a general OBD reader then that explains why you didn't get any codes.
Old Aug 17, 2012 | 07:21 PM
Dublin's Avatar
I used a expensive one my friend borrowed from the dealership
Old Aug 17, 2012 | 07:25 PM
jonbonesjones's Avatar
Moderator
looks like a brake pad indicator light. The only ABS lisgh is to the right not in the center screen.
Old Aug 17, 2012 | 11:01 PM
Tweaked's Avatar
The amber warning in the center is a brake pad wear indicator light.
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
