ABS light on and brake light flashing
I found the misfire from the previous post and it was from the ignition module. I opened it up and soldered (poorly I might add) the bad connection until the new one comes tomorrow. Found that the oil leak was from a loose hose from the turbo to the oil cooler. I am trying to find the problem with the ABS. the dealer was no help. they were wrong about the catalytic converter, wrong about the turbo, wrong about the oil leak, so I am leary about the abs module they said was bad. He said the turbo was bad and didn't even look at it. the inlet hose was never removed, and the cat was seperated from the flange where it mounts to the turbo. Dealer said it was a stopped up cat. if it was stopped up enought to break the spot weld the car certainly wouldn't run. Anyway, whats the common problem for the ABS light coming on with the brake light flashing? Soooooo many problems and the woman is not happy, but otherwise the car is beautiful with only 89k on it and I paid only $250 dollars for it.
milo55041
Dec 15, 2017 01:14 PM
tonygump
May 10, 2011 12:41 AM
jjock
Sep 10, 2009 08:23 PM
